wearing rubber gloves?
simple
How many people wear latex or latex free rubber gloves when working on their vehicles? (especially changing oil) I thought I might try some, but I'm worried that the gloves might melt when contacting hot engine parts.
I thought about it once but was also worried about the melting so I just bought a pair of Mechanix gloves and love them.
I would think that anything that would melt that glove would be hot enough to burn the sins out of your hands. So they're probably safe to wear.*
* I am not a doctor, engineer, lawyer, hazardous materials handler, a personal safety gear consultant, nor do I work for OSHA. So take my advice with a bit of salt.
I did stay at a Holiday Inn Express last night though. :flag:
Yes, but if you look at my gloves and the arms of my racing suit you will notice that I tend to frequently rest my arm or grab the header straight off the track. :flag:
A dentist noticed that his next patient, an elderly lady, was looking very
nervous so he decided to tell her a little joke as he put on his gloves.
"Do you know how they make these gloves?" he asked.
"No, I don't" she replied
"Well," he spoofed, "there's a building in China with a big tank of latex
and workers of all hand sizes walk up to the tank, dip in their hands,
let them dry, then peel off the gloves and throw them into boxes of the
right size."
She didn't crack a smile.
"Oh, well. I tried," he thought.
But five minutes later, during a delicate portion of the dental procedure, she burst out laughing.
"What's so funny?" he asked.
"I was just picturing how condoms are made!" she said.
Gotta watch those little old ladies! Their minds are always working!
...Sorry, but I just had to post this joke I got this morning!... :D
