LMAO!!!!
Cool Zr2
I am watching that movie on TBS now, Some cop movie with cindy crawford, they haven't repeated the name on the comercials so I don't know what it is named.
It was funny when that cop yelled at that criminal and the criminal pointed the 357 at his head and then he smoked the criminal in the face with the keyboard.... and then a fellow cop said "That was...... Probably stupid." LOL
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
