Headers cause worse gas mileage?
Put my headers on back in Dec. Noticed a drop in gas mileage about 2 months later. havent driven the truck any harder than before. Probably even got off it some bc of rising gas prices. I was thinkin that possibly my o2 sensors are readin more exhaust and thus causing my computer to flow more gas to the cylinder. Changed my fuel filter last night so I dont know if that will solve the problem. Filter didnt have dark gas come out. Gonna cut it apart tonight and see whats inside.
Anybody have any thoughts on my mileage decrease?
Headers typically hurt the engine down low. Less backpressure down low (rpm) means less torque on a non-turbo'd gas engine. That means more throttle to get the same torgue at a given rpm down low. Higher in the rpm band, less backpressure helps with HP gain.
What diameter are your tubes? 1 5/8" or 1 3/4"? The smaller the diameter of the runners the less it hurts torque down low. Are they short or long runners. Long runners seem to be better than shorties down low as well.
DEWFPO
"Back Pressure" = BAD! Stuff a potato in your tailpipe while the engine is running, thats back pressure.
Its Velocity that counts. If exhaust pipes, including header primaries are too wide, it decreases the velocity of the exhaust pulses, decreasing the scavenging effect with helps build torque. Its been said that shorty headers have minimal effect on performance since stock manifolds on new body style trucks flow practually just as good as shorties.
They are shorty headers, I do not know the size nor have i seen it online yet. The air filter is a K&N filter and just put a new purolator fuel filter in. My buddy was tellin me to stick in a paper filter, which was more restrictive so not as much air would enter the cylinder.
    CaptainDad
    CaptainDad
  • Who's Online   5 Members, 0 Anonymous, 487 Guests (See full list)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
