am70043 Posted April 1, 2005 Posted April 1, 2005 22.000 mi. and figure it' past time for a fuel filter change. Is any one filter better than another, or should I stick with AC Delco. What's your choice?
MS3DALE Posted April 1, 2005 Posted April 1, 2005 AC-Delco,Of course they took the fuel filter off of some of the '04's
Indy Posted April 1, 2005 Posted April 1, 2005 22.000 mi. and figure it' past time for a fuel filter change. Is any one filter better than another, or should I stick with AC Delco. What's your choice? <{POST_SNAPBACK}> I just replaced mine with an AC Delco at 70,000 miles and it still looked clean. I think 22,000 miles is a little early for changing it.
Bish Posted April 1, 2005 Posted April 1, 2005 22.000 mi. and figure it' past time for a fuel filter change. Is any one filter better than another, or should I stick with AC Delco. What's your choice? <{POST_SNAPBACK}> I just replaced mine with an AC Delco at 70,000 miles and it still looked clean. I think 22,000 miles is a little early for changing it. <{POST_SNAPBACK}> Beg to differ on the change interval. 1 tank of bad gas can plug the fuel filter and will cause the pump to fail prematurely. Yes, if you never get any bad gas, it could last much longer. But, at $600 to replace the fuel pump, I will replace my $10 filter every 1000 gallons or around 10,000 miles. I also don't run the tank below 1/4 tank because the fuel is the coolant for the pump. ACDelco is my preferred brand but I have used others.
MS3DALE Posted April 1, 2005 Posted April 1, 2005 Yes,70,000 is waaaaay too long to go before changing it.I used to go 20-25,000 miles between changes.
Indy Posted April 1, 2005 Posted April 1, 2005 Yes,70,000 is waaaaay too long to go before changing it.I used to go 20-25,000 miles between changes. <{POST_SNAPBACK}> I just read my owners manual and the first fuel filter change is listed for 60,000 miles.
fastdrvr23 Posted April 1, 2005 Posted April 1, 2005 I changed mine at 30,000 with an AC/Delco OEM replacement. No problems, easy to take care of. I figured I'd rather stick with AC, it was only like $11 anyways.
Harvey Halabookie Posted April 1, 2005 Posted April 1, 2005 AC-Delco,Of course they took the fuel filter off of some of the '04's <{POST_SNAPBACK}> So what are the suggestions for those of us with no filter? Is there really no filter or is it in the tank? I'm thinking of installing an aftermarket filter in-line.
MS3DALE Posted April 1, 2005 Posted April 1, 2005 AC-Delco,Of course they took the fuel filter off of some of the '04's So what are the suggestions for those of us with no filter? Is there really no filter or is it in the tank? I'm thinking of installing an aftermarket filter in-line. Yep,Its in the tank,they call it a strainer. I have not looked into adding an aftermarket filter but I would if its possible.
100R1 Posted April 2, 2005 Posted April 2, 2005 Purolator part # F33144 replaced on my '01 Yukon I replace evry 20,000 miles. Time to do it again.
tmf6902 Posted April 2, 2005 Posted April 2, 2005 I replace every 25K or so...and use either an AC delco or Puraltor...depending on what the store sells.
