6 Disc in dash CD
Hi everyone what a great day about 70 here. Anyone putting that big ole boom box etc stuff in there S-10 and taking out the factory 6 disc in dash unit, i would love to have one sometime. Mine is a 2003 extreme. im thinking that is the only year for the 6disc but not sure. Anyway keep me in mind.
john :cheers:
