Tranny Problems
On my way to work today my truck ('99 NBS Silverado 140 K)
decided not to shift out of 2nd gear. Never had a tranny problem
with this one before. There are no grinding noises or anything else.
Anyone have any ideasas to what to look for??
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
