'94 5.7L has developed a "ping"
My '94 Suburban 5.7L has developed what I would refer to as "ping" over the past few months. This typically occurs when the engine is under load, such as going up an incline prior to downshifting. Once the tranny downshifts, the noise pretty much disappears. I have tried different fuels and haven't noticed much of a difference. Is this indicative of a need for a tune-up, or some other problem?
I wil be doing a complete tune-up in the near future, as I am experiencing rough running at times when it is or has been wet. I'm assuming moisture is getting into the cap, wires, etc, causing the rough running until it dries.
Appreciate any thoughts!!
I have a 89 4x4 burb with basically the same engine that I have had since new. I discovered early on that I could never get it to run right or not ping on 87 since I had it and use 89 durring winter and 93 in summer even today with 170k on it. If I retarded the base line timing enough (to stock or more retatd yet) to get it to stop the performance and MPG suffered. Now I run 6 BTDC and it runs like a top and will hit 18mpg if you keep it under 65 on the road and do 17mpg at 70 or less. With regular and retarded timing I was lucky to get 14 or so on the road with AC on.
