Silverado sound system help
Allright first time poster, just getting started. I have my subs and amp in my truck. I'm running the amp off a distribution block (also have a smaller one for 6x9's), and i have a digital readout cap too. My whole system, no matter how loud i had it would get quieter and start crackling before, and the voltage, according to the readout, would drop from the normal 14 or so, to 8, and the cap would start beeping. It did this whenever i turned it on, so i pulled the fuse. So, i redid my speaker wire, and it works pretty good, except, when i apply the brakes moderately, or hard, the subs and 6x9's loose volume, and start crackling before, but as soon as i let up on the brakes, they run great. Anyone know why, or how to fix it? Also, my 6x9's crackle when i turn it up, and my subs are pounding, but they are only 2 months old, so they can't be blown (i think). Grounds are all tight, fuses good, everything seems allright. Thanks, i appreciate all the help i get!
Sounds like it's time for the alternator upgrade. Looking at the year of your truck, I think soon it will be history anyway.
Yes, that's why you are getting 8V at idle, you are demanding too much. Brake lights go on, zapping the overhead. That amp is pulling 20-40 amps if you have it cranked. A 90 amp alt, several years old, at idle, maybe delivers 40 (for the whole car).
That's my vote. You could replace the battery with a yellow top, battery may be on last legs too.
Hey, welcome to the forums :banghead:
It sounds more like a problem with the trucks electrical system, not the stereos.
You might want to consider a bigger alternator, and perhaps a second battery.
Just curious, but where in the heck did you squeeze 6 x 9s in there?
Thanks for the advice so far...
Well, i just put a new alternator in a month ago, stock sized though, with a lifetime warranty too. The battery is old though, i may swap it.
I've had this whole system in my old 92 Grand Prix since october, and i transferred it into my new Silverado about 2 months ago. It worked great till about a week ago, when it started acting up. :banghead: Grrr!
One more thing i noticed when i was driving to work today... The voltage drops only when the truck is driving, and i hit the brakes to slow it down. Not when i'm just idleing, and hit them. It also is only dropping voltage to the subs, cause my cap readout drops, but my guage on my dash is still good.
O and my 6x9's are mounted in boxes on my rear seat right now, but soon i'm going to cut a hole in the side panel itself through the exhisting speaker grilles in the rear, and mount them onto it, and take the 4x6's in the rear out. Seen it done like that a few times.
Start at the system roots. Measure the voltage across the battery with and w/o brakes on. Perhaps you have a short with the brake harness that is draining the system. Disconnect the 6x9's and repeat, are they possibly faulty and drawing down the amp, etc. You can figure it out.
But my bet is still on the alternator, even moreso since you said it was new. We never pay attention to capacity when replacing parts, and frequently the cheapest option is worse than the core. Also, if new (rebuilt more likely) it will sink or swim in the first few weeks. Check what capacity it was, then call GM with your VIN to see what the truck came with.
Keep in mind, if you just replace the battery, everything may seem "fixed" while the fresh battery will mask the problem for awhile, until the battery can't take the constant charge cycling any longer.
As for the problem at speed only ??????????? Sorry, can't think of why.
Can you duplicate the problem at idle when you throw all lights/ accessories on?
Had almost the exact problem in my Tahoe last year. Everything worked fine until I would come to a stop sign, or occasionally at idle. I would notice my voltmeter at 14-16 volts while driving, and then while stopped it would intermittently drop to 10-12. You could be experiencing the same thing. Try "two-footing it". Take it on the freeway and apply the brake slightly while keeping a steady speed. See if the same thing happens. If it does, I'd say short in the brake circuit (or worse). If the voltage stays steady, check out what my problem was:
It turned out there was a lot of carbon buildup in the throttle body. Took it in, had it cleaned out, and it cleared up all the electrical problems I was having. I now take it in every 15k for the same service.
That makes no sense to me ????? please explain the relationship between electrical performance and carbon in the HP tract.
Guest 007FL
More info please;
I'm concerned about the "distribution block" comment.
Did you run an amp power cable direct to the battery or pull it off something already in the truck?
Are the 4x6's and 6x9's powered from the amp or the head? If they are off the head you may want to consider running a better power cable for the head.
At any speed other than an idle a stock system should power an 1800W amp just fine. If not (and assuming you are direct to the battery) you have either a battery or an alternator issue, either of which should show up in the charge meter.
JMHO
Basically, what I was told, is that when the buildup reaches a certain level, the the computer (erroneously) tells the engine to idle at a lower lower RPM, and it had a DRAMATIC effect on my overall vehicle voltage. I thought it was the typical dealer BS, but it was under warranty at the time so I had them perform the service. My voltage problems were gone. No more headlights dimming at the stop sign, or other oddities. There are several bulletins regarding this on the web.
I am running a 4 guage directly off the battery, and have a distribution block, with 2 8 guage outputs. I am running only the 6x9's off the small amp, the 4x6's are run off the headunit.
O and i ran it out on the highway, and when i give it gas, and put on the brake at the same time, it doesn't cut the system out, its only when i let off the gas, and apply a descent amount of brake, and like dbcomm said, sometimes at idle.
I might check with the local mechanic about this throttle body buildup thing.
The alt absolutely should provide enough juice for the lowest idle speed the vehicle will ever see. many vehicles have stock alts that barely keep up with the stock truck. Add a bunch of load to it, and you have a power deficit, pretty simple. It's not the battery. Even with a shot battery, the charging system runs the vehicles electrical system
The simplest start is checking the charging voltage. You evidently don't have enough juice. It happens to a lot of people who accessorize or undersize there charging capacity.
Pull off the alt, take it to checker and have them load it. They have a nice little machine that will tell you all about the alt performance...
You have to start somewhere...by getting dirty. Since you have already confessed that the system is under voltage, your problem sounds classic. Most stuff needs 9-11 volts to run properly, it is damaging your stuff to run less than 11V.
BTW, I have a harley dresser that does exactly the same thing you describe. The radio cuts out when I hit the brakes, YOU HAVE AN ALT ISSUE! Get more capacity.
I'd check to see if somehow your body-to-frame ground is corroded or disconnected, and the way to do this would be to wire a volt meter up with one lead going to a body ground (like your amplifier's ground), and the other wire going to a frame ground (run a special wire out the window and to a bolt on the frame, or to the negative terminal on your battery). If you ever see voltage between the two, that would explain the problem.
The instrument cluster is probably wired to a frame ground, and that would explain why it doesn't see the voltage sag. But your brake lights, and the audio system amplifiers probably are wired to a body ground. A weak or corroded body to frame ground strap, coupled with the increased load of having the brake lights on, coupled with the body moving slightly on the frame when braking, might cause the problem.
Are you saying your dash gauge doesn't drop below 12V at idle??????????
This is frustrating. Shut off the motor and stereo. Guage reading? Turn on ignition and all lights, what does the gauge read? Turn off lights. Start motor. What is new gauge reading. Turn on stereo, motor running. Reading? Crank stereo. Reading? Now step on brakes. Reading?
The answers will define your problem.
    • Replace the fuel pump with an OEM AC-Delco.
    • Hello, first time posting here. I have an 03 Chevy 1500HD with the 6 liter gas engine. The truck ran fine until the fuel pump died on me and had to get it towed. Replaced the fuel pump with a precision pump from O’rileys and changed the fuel filter while I was there. The truck will run and drive now but it wants to idle around 500 rpm when in drive and it tries to stall if you touch the gas. It drives fine though, just doesn’t want to idle. Put a fuel pressure gauge on the rail and only have 50 psi. I guess these trucks should have 55-62 psi to run right. I thought the regulator might be the issue because when I would unplug the vacuum hose it jumped to 56 psi. Replaced the regulator and no change. The only thing I can think of is that I was sold a faulty fuel pump. Any help would be appreciated because I’d rather not have to take the bed off again if I don’t have too. Thank you!
    • I've been wrenching on GM trucks for 17 years. And I need to get something off my chest because it's been weighing on me for a long time. After all that time, all those motors, all those people standing in my bay, I've figured out there are really only two kinds of owners. The ones who already know about this. And the ones who are about to find out the hard way. A guy came into my shop a few weeks back in a 2018 Silverado 5.3. Sharp guy, maybe 35. Knew his truck cold. He'd been on the forums, read the threads, done his homework. He only rolled in so I could double-check a little module he'd already plugged in himself. Wanted a second set of eyes on it. Ten minutes, in and out, drove off happy. Two days later, a completely different story walked through the same door. Older fella this time, in a 2016 Sierra. Gorgeous truck, clearly babied, not a scratch on it. Wedding ring. Looked like a guy who took care of his stuff. He was in because his engine had started knocking on the way to work. And by the time I got the valve cover off, I already knew it was too late. Lifter collapsed. Cylinder 5. Camshaft chewed up. The whole top end shot. Same kind of truck. Same motor. Same roads, probably the same dealer. The only thing separating those two men was information. I've been at this since 2008, and I've worked on everything GM puts out. Silverados. Sierras. Tahoes. Yukons. Suburbans. Escalades. The 5.3 and the 6.2. Doesn't matter which badge is on the tailgate. They all carry the same problem. So here's the information one of those guys had and the other one didn't. It's called Active Fuel Management. AFM. GM started building it into their V6s and V8s back in 2007 to squeeze out a little better mileage on the highway. Maybe a mile or two a gallon. All to hit government fuel economy numbers. The way it works, the motor quietly shuts down half its cylinders when you're just cruising along. And the little lifters that pull that off have a tiny pin inside them that's constantly clicking in and out. Lock, unlock, lock, unlock. Hundreds of times a drive. Thousands of times a week. Eventually one of those pins wears through. The lifter drops. And it starts grinding the camshaft down like a chisel on butter. And what nobody tells you is that the shudder you feel around 40 or 50 mph? That's the system cycling. Every single time. Here's what really gets me. The pre-2007 trucks, the ones without AFM, they're bulletproof. I've got customers still daily driving them with 260,000 miles on the odometer. Not a problem in the world. GM took a perfectly good motor that would have lasted a lifetime and bolted this system onto it. And it is wrecking engines that should have run forever. The guys who hang around the forums already know all of this. So do the techs. They handled this years ago. They didn't sit around waiting for the dealership to mail them a warning letter, because that letter is never coming. It's the guys who figured somebody would've told them who end up on my lift. And I want to be clear, because this part matters. Maintenance has nothing to do with it. I've torn down motors with barely 30,000 miles on the clock. I pulled apart a Tahoe last summer with 24,000 on it. Practically a brand new truck. Owner had it less than a year. Spotless oil. Best synthetic money can buy, changed early every time. Made no difference. I've seen guys with full dealer records, every interval stamped. Made no difference. The oil changes were never the problem. The pin was. And no amount of babying that truck stops that pin from cycling every single time you drive. That's the part that eats at me. These are good motors. Take the AFM out of the equation and a 5.3 or a 6.2 will run 300,000 miles and never blink. So a few years ago I started telling every single owner who comes through my doors the exact same thing the smart guys already knew. Get yourself a FullForce disabler. It plugs right into the port under your dash. Couple of seconds and you're done. It just tells the computer to leave every cylinder running, full time. No more cycling. No more beating those lifters back and forth every time you turn the key. It doesn't reprogram anything. Doesn't touch your tune. And unplug it before a dealer visit and there's absolutely zero trace it was ever installed. I've had customers come back at 40,000, 60,000, 80,000 miles after I put one in. Zero issues. The trucks run smoother. And the lifters aren't getting beaten to death every single drive. I won't sit here and tell you it's magic. A lifter that's already damaged is a lifter that's already damaged, and this won't un-ring that bell. But it takes away the one thing causing all that wear in the first place. That's the whole game. You don't need a five-thousand-dollar delete. You don't need an expensive tune. You don't need to tear anything apart. You just need to stop the cycling. I'm not writing this for any company. I'm writing it because I'm tired of watching the guys who didn't know pay four and five figures for it. I'm tired of being the guy who has to break the news. I'm tired of knowing that the guys who did know fixed the whole thing for the price of a tank of gas, and the only difference was that somebody told them first. If you drive a Silverado, Sierra, Tahoe, Yukon, Suburban, or Escalade from 2007 or newer with a V6 or V8, you've got AFM. You've got those lifters, and they're cycling every single time you drive. So be the guy who already knew. Not the one I'm scraping metal out of next month. EDIT: A bunch of folks asked, so here it is. The one I put my faith in is FullForce. This is where to find it: https://www.tryfullforce.com/products/fullforce™-afm-dfm-disabler They back it with a 60-day guarantee too. I've handed out more than I can count and not one's ever come back to me. Not one. See less
    • Thanks for following along. I'm not author material, my tenses are all over the place and an editor would have a heck of a time cleaning up after me. Reading and writing is still a fun pastime though.   My new scanner came in yesterday, wow, where the heck has this thing been?! It connects right up to the Blazer, there's all kinds of bidirectional tests like EGR activation and percentage, toggle the fuel pump relay, EVAP purge valve, IAC control, AC relay, reset the transmission's adaptive learning, toggle shift solenoids and TCC lockup, and I can reset fuel trims with the click of a button...all things I could have used over the last 60 days!   It's also telling me there is a stored code in the ABS module for front left wheel sensor open and something about the brake switch. The ABS dash light works. It illuminates normally during the self-test at key on/ start and that's it. I cleared the codes and will see if they set when I take it out later. That, and I'm going to get (hopefully) real data on timing and cam ******. The PID's are there.   I connected the tool to my truck...holy smokes. Newer vehicles make early OBDII vehicles look like 8-bit, pixelated, early Nintendo stuff. This? This is like wearing 3D virtual reality goggles playing one of those elaborate, cinematic video games with seasons and plots in comparison. There are SO MANY modules and SO MANY tests and SO MUCH data. There's a scanner sequence for filling the coolant...   End of the day, it's a tool with way more power than I need, but the versatility to do old and new is there (and I need an adapter to connect it to my OBDI Camaro). It will allow me to do the first pass of diagnosis when out-of-warranty vehicles need help, and it will enable more DIY maintenance like brake system bleeding, ABS bleed, etc. I probably over-bought here, but, mission is accomplished.   Enjoy your Sunday...I need to shut this machine down and go get ready for the week ahead.
    • Not that I've read, after all the issues they've had in the past I'm pretty sure they learned their lesson.
