silverrado 1500 short bed 2001
how can i lower the back of my 2001 silverado to make it level with the front
just wondering if i can do it myself or need to take it to a mechanic can anyone
help me with this
help me with this
If you are concerned about gas mileage dont do it. Other wise you will need a different spring if its a 2x4 and if it a 4x4 you can have the torsion bars adjusted and have the front end aligned.
help me with this
Not a FLAME, but how dose lowering the back of a 4X2 with shackels afect your MPG :thumbs:
Rich G.
[ Not a FLAME, but how dose lowering the back of a 4X2 with shackels afect your MPG :thumbs:
The air going under the truck is subject to catching anything on the chassis. Raising the rear cuts the drag since the underbody isnt smooth. Check the underbody of a 97-04 Corvette its smooth.
Also removing the blocks changes the pinion angle and will damage your u-joints. :cheers:
well having the rearend up higher increases the drag on the top of the truck and lowering the rearend increases the drag underneath the truck. It's a lose lose situation if you want to think about it that away. removing the blocks won't effect the pinion angle that much to cause any more damage than a truck that is lifted 2". That's something I wouldn't even consider being a problem.
if it is a 4x4 you can also remove the blocks in the rear to drop it 2"
if it is a 4x2 you can buy lowering shackles
You can use 2" lowering shackles whether its a 4x4 or 4x2. If its an extended cab...you need a shim kit to correct the pinion angle. Regular cabs don't need a shim kit. DJM and Belltech make good products...check out their websites. As you can see from my pick, they level the truck out. Good luck :thumbs:
