personalized tags
facn8me
I 've seen a dark green stratus in town with the tags "facn8me"....:confused: \
for the camaro I've thought of several, not sure which tho
SEE-YA
BUHBYE
1STGNRS
ULLOSE
AND MORE, I had some really good ones but can't remember them right now.
Funny you mention that tag. :confused: About 9yrs ago I was tryin to sign up for my first internet account. I tried everything I could think of. All kinds of things. Finally I remembered seeing a personalized tag that said "facn8me" and now you know the rest of the story.
Edit: I know those people hate me cause i have facn8me screen names in everything msn hotmail aol yahoo cox and many more. :lol:
On my Impala SS I had 96BBBSS year, color, and Super Sport
I was going to order this plate for my CVPI
WUZFUZZ
but I sold the car.
not sure if I am getting one for the truck yet...
