What other truck sites?
Ulmus
I'm just curious. What other truck web sites do you go to and what do you like about them?
I like cardomain.com for its information about sound equipment. And the posts there are pretty mature. The advertising is a little more obnoxious, but if you deal with it you can learn stuff to help with your current project. It (the website) has a pretty well thought out mix of features. It gels.
Silverados at CarDomain.com
Check out the totally radical...
Silverado Subwoofer
Although most are best answered here, there are some questions about your truck that are best answered elsewhere on the internet, and cardomain.com has given me good information many times.
I must say, though, that this site is by far the best I have found. Good group of people. GM Owners. Kind of makes you proud.
I actually found this site through www.chevytalk.org. They seem to have a forum over there for just about any car or truck chevy ever made and I kinda consider it a sister site as far as the late model truck talk goes.
The guys in the 99-current truck forum over there are a pretty good bunch, although that site does not seem to get the posts that this site does. I know there's a number of guys in here that also post over there too.
I am a forum whore...I am all over the place.
Aside from here I visit Silveradoss.com, the impalassforum.com, classicgmtrucks.com, 67-72chevytrucks.com, and I have been on sportruck.com for about 7 years now.
PUTC, I don't like it that much anymore. I joined ChevyTruck World when it was brand new, and never really got into it. I made like 100 posts, then I quit visiting. It was boring over there. I went back for the first time a few months ago, and couldn't believe how much it has grown :thumbs:. I like this site the best by far, but Chevy Truck World isn't bad either.
Others? I'm not aware of any others.
May the fleas of a thousand camels infest your nether reigons for even suggesting such a thing.
Fer shame. :thumbs:
Fer shame. :thumbs:
I think we need to start our own little "autointernet-ethnic cleansing" :seeya:
