blacking out white letters?
I was curious if anyone has figured out a way to blacken white letters on tires. I bought some new tires and have the blackwalls facing out but you can see the letters under the truck. I know this is anal, but is there a way to color these? I suppose some flat black spray paint would work, but would it last or mess up the balance of the tires? A big permanent marker? Gimme some suggestions.
Thanks
Matt
Dont think a little bit of spray paint would throw the balance off of your tires, but if they were mine I wouldnt spray paint them or anything on my truck....Black marker will probably be your best bet...
If found M.E. Miller Black Tire Paint when I was shopping for tires about a year ago. Decided not to buy the tires I was looking at that I would have needed it for. You might be able to get a local tire retreader to sell you a smaller amount, don't need much as I recall.
http://www.millertire.com/repairs.asp
I had my Revos mounted white letters inside...
I got a pint can of black tire paint at Kragens (or your local auto parts store) and used a small round tip art brush about 1/8" dia. and just painted the raised white area of each letter. It only took about 5 minutes a tire. I did take each tire/wheel off and flip it over to make painting easier that laying under your truck.
The result is, it looks great!
There used to be a stuff called "tire black" If I remember right Dupont made it and it was just for that purpose.
firestone uses it, maybe they can spray them for you or give or sell ya a can
    • Which one, the AT or AS?   Starfire is made by Cooper/Goodyear but at $85/tire I'd think I'd need to level-set my expectations that they may not even be round 😉 But you're saying they're decent?   I'm already into this thing $1506 in parts, fluids, etc. Totaled all my receipts today. $250 of that was replacing an EGR and MAP sensor that were probably fine, but I'm not going to return the parts since they've been installed. I'm cheap, but not that cheap. I use it, I keep it!   I may or may not make money if I sell the truck at this point, but, that wasn't really the point. And if I billed my time, I'd be hosed for real. My thought on the tires is I "might" put 1,000 miles on before selling it. I just don't want to put absolute junk on it, that doesn't do anyone any good. If the Solus solidly isn't junk, I'll definitely consider them.
    • I leave mine as is. I'm always a trip away from riding on unpaved roads. Dealer can clean it when they prep it after I trade it in for another new truck.
    • I have these on two vehicles and love them. Pepper is one of them 😉
    • 4WD. Far as I know it came stock with P's and not LT's. Definitely planning to put P's on it, but stock is a 109 XL load rating so I should probably stick within that guideline.   No rebates on anything I can see at the moment. Discount Tire is offering $50 off, but Pep Boys is very competitive on price, and also carries all the off-brand stuff. Les Schwab always wants an arm/leg, but they do good work.   It still has the original spare. Goodyear Wrangler RT/S, thing looks like a tractor tire LOL!! How times have changed.
    • 2020 Sierra 2500 HD (base model) gas engine 4wd.    All 4 windows roll down on their own. Happens somewhat randomly after stop and engine off - when engine turned off, when walking away from vehicle before or after locks activated. Pulled the window fuse F14 Instrument Panel Fuse Block Right; the driver's side still activates from driver's side door panel; passenger and back seat windows activate from local switches on their doors but not from driver's side group of switches. Power mirrors don't activate with fuse removed either (same fuse for both circuits). Problem not solved.    How can they even activate with fuse removed but they are all still opening and can control from each door?  When they open on their own, I can shut them from the switch in each door, but they don't stay closed.    Seems to be activated somehow with key fob; something bumping the key fob in my pocket or just handling - removed key fob and took it far enough away and now the windows stay closed. Replaced key fob batty just in case, no change.    Sounds like some kind of wiring short or maybe electronics. Dealer will first replace electronic control module without checking anything else and I anticipate problem will still exist since their troubleshooting skills are limited to "do whatever the computer says".  In any case, keyfob seems to be activating the circuitry.    Surely I'm not the only one with this issue, but I can't find anything related on the site. What do yall think?   JohnRoy
