Removing center piece in 40/20/40 bench
I was thinking about getting bucket seats, but then I thought...  Is it possible to just remove the center section of the 40/20/40 bench??? I mean, the only dif between the bench and bucket is armrests, which is no biggie.  If I could take out the center part I could get an aftermarket console in there.
It will work..  I heard it unbolts w/the two front seats, just like the consoles.  I have seen the part #'s somewhere for the center console replacement.
I think I saw a pic on sounddomain.com where someone had removed it for more speaker & amp room.
Jason Pendlum has instructions on removing it @ http://users2.ev1.net/%7Ejpen....htm
I
would go ahead and get the Denali Center Console if you are going to buy one.  See http://users2.ev1.net/%7Ejpendlum/Web%20Pages/Parts.htm for pics and part #'s.
(Edited by chane at 5:27 pm on Sep. 13, 2001)
I just ordered some graphite carpet for my truck, so hopefully I'll get that within the next week and when I take out my seats to put in the carpet, I'll just leave out the center piece.  Also, I think that I might build a custom center console.  Not sure yet, I'll have to see what everything looks like.  and if it's feasible.
Why did you order graphite carpet?  What color is your interior now?  How much?
What would you build a console out of?  I have seen the new center consoles on eBay before..
I've got a graphite interior so that's why I went with graphite.  I ordered it off of www.gmpartsdirect.com and w/ shipping it came to a lil' under 200.  My truck is extended cab, so if anyone has a reg. cab it would be cheaper I'm guessing.  I'm not sure what I'm going to do about building a center console, I'll figure that out later.  I'll check ebay to see what I can get a center console for, might go that route.
So how much cheaper was you truck by getting the base model?
I probably should have done that since I'm changing everything out anyway.  Instead of getting a loaded LS, I could have got a base z71?
Mine isn't a Z71, it's more than that.  I have the high capacity air cleaner.  I have the cast aluminum rims.  I bought the additional skid plate for 60 bucks and I upgraded to rancho shocks.  But by upgrading it myself, I save money by not replacing components that I paid for such as a factory cd player or the z71 package shocks.  It takes more work on my part, but hopefully it will prove worth it.
The center console does unbolt.  I had all the seats and trim out yesterday wiring in a stereo system.  The bolts holding the front seat are a bit odd.  The require a 12 point socket.  I found a 15mm for the front and a 11mm for the rear bolts worked well.  You can remove the center by removing the inboard bolts on both outside seats and loosening the outboard ones.  Rock the seats outward and slide the center console out and over the locating pins.  Highly recommend a assistant.  I had all the seats out and did it by myself.  Vehicle in question is a extended cab 99 LS with power seats and the seats are suprisingly lightweight.
One thing to note, the bolts appear to be coated with a loctite type material.  You may consider recoating them when done.
Just pulled out the center seat yesterday, I've got to say it really makes the cab roomier, now I need to find a center console.  It would have been easier w/ two people, but w/ a little grunting and a couple of swears I got it out.
make over on the truck??....start with escalade front clip, 22'' rims, denali console, leather, escalade door handels, black paint, full sound sys., and neting else u can get from an escalade
    • Of course refrain from political debate but I myself have very dismal hope for what is all going on up here every where we turn so I nodded my head when I saw this joke.
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
    • Got this yesterday out of nowhere. Truck is a 25',6.6 gasser with 8k miles.  Only semi anomaly is that the truck had been sitting, uncranked for 6 days. Elec Stability Control showed immediately upon cranking, not while driving. No drivability issues, just the message. Battery didn't seem to be weak when cranking over.  I drove it, killed it, let it sit a few hrs with no avail.  Truck is 100% stock. No damage.
    • This can be done.  It is not cheap and requires an instrument cluster swap with custom programming, new steering wheel with the controls on it, and a special jumper harness.   The cluster upgrade - 12.3” Digital Cluster Upgrade – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The wheel upgrade - Steering Wheel Upgrade Kit – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The column harness upgrade - 2019 - 2026 Silverado / Sierra: Steering Wheel LIN Bus Harness - Harness Dr. - DIY Done Right     The problem with doing all of this?  You pretty much can't have any programming done to your truck that involves the cluster ever again.  The dealer won't be able to program the cluster as GM's system will only pull data for the cluster the truck came with.  So it would be advised also to turn off over the air updates.   TLDR;  Should have bought an LT double cab?  You'd have a power seat, the wheel controls, the cluster, all things that you've been seeking in your various posts so far about your new WT regular cab.
