05 hd lift
Would like to put 33"tires on 10" rim on an 05 2500 Hd CC D/A . What is the best lift? Is 3.73 ok with Duramax with that tire? Plenty of power now! I pull a 5000# Trailor Daily. Thanks For Any Help!!
IMHO if you are going to use 33s I would use an 8" rim instead of a 10". To me 10s stick out too far especially if you go to a spindle lift type of kit.(RCD, Fabtech) The Dmax will give you plenty of power with the 3:73s and with the 33s your rear axle(AAM 1150) will be more then up to the task. As far as the best lift,you will get many opinions about that. It's usually based on what works best for that individual and depends on what type of tasks the truck is used for. I have an RCD on my 02 Burban and I am very happy with it. :confused::cry::troll::troll:
i have 33's on 9" wheel with a 4" suspension lift. my truck is a 2001 Z-71
so your truck will be starting out 2" higher than mine. because it is a
2500. here is pics of my 33's truck
