Whats the Autotrac switch part #?
My moms truck is now giving her that stupid message. This should be a part that gm just covers, regardless of the year and mileage. Shes only got 20k miles on her 2000 Z71. What actually happens to these switches? They melt down inside or something? What makes the new ones better?
Part number for the Autotrac switch is 15709327 and lists for $59.55.
I can't answer what happens inside,if they short out or melt or what!
All I know is that we were changing a lot of them here for the first couple of years when these trucks first came out,and we still sell about one a month over the counter.
Might want to take a look at GM Parts Direct. They list the price for the part as $33.94. Good luck.
vroten :thumbs:
What happens inside? My experience is that the solder for the connector pins cracks around the pin, making an intermittant contact. This seems to happen to the ground since all the lights go out, i.e., indicators and backlights.
What makes the new ones better? Nothing... It's just another time bomb ticking and it will probably fail after a couple more years.
Electronics and temperature cycles don't usually mix well unless the board was laid out correctly with the proper size through holes for the pins. I've been wondering if GM has gone to lead-free solder, which requires a higher temperature. It may also be more prone to cracking, although I've seen cracking around pins for many years. Same thing happened to my rear view mirror on my current pickup and the wiper motor board on my '92 Z-71 I had.
Hope this answered some of your questions... :thumbs:
vroten :seeya:
Most people use GM Parts Direct a little less than twice. The first because it seems like a real good deal on genuine GM parts then NEVER again because people realize they got the Dirty Sanchez on freight.
Flow Chevrolet, the masterminds behind GM Parts Direct, Winston-Salem, NC (336-760-7050) pimps parts at dealer acquisition cost but makes up for with freight markup. In all reality, you could buy the same part from your local GM dealer for less. The good news it if you want to know the actual dealer cost on a part use their website to find out.
Oh, I can’t pass up this opportunity to say….Gotta love that push button transfercases. The problem threads just keep pouring in. Levers people, levers….buy trucks with manual transfercases. How many problems have you seen with manual transfercases???
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
