Hey guys I had my 4L60E rebuilt a while back, shifts PERFECTly ever since then. Here's the problem though. It's more evident when its cold out, but it makes a knocking sound. It goes away when it warms up, but is still there slightly. It is evident in all gears, except when I put it in reverse it completely goes away.
Any ideas? Oh yea..it's in a 95 Blazer 4x4
Joe
Joe
Does the knocking vary with engine speed or vehicle speed? Is it any worse when 4wd is engaged? If the engine is warmed up but not the trans, does it knock like cold or warm?
It varies with engine speed. Tried some more stuff today in the driveway, it was very evident in park or nuetral, but then in gear anytime with a load on the engine it disappeared....
Now that you have it narrowed down like that, I think it's time to go visit the guy who rebuilt the trans and ask him what the noise is and why it goes away when you tighten up the drive train.
:thumbs:
Sounds like its the U-joints. If the U-joints are bad they make noise when you are cruising, but as soon as you put a load on the joint the noise stops.
If it's u-joints, it'd be road speed related, not engine speed related. But it might be the flex plate at the front of the trans...either cracked (fatigue cracked) or maybe not bolted on properly. Might be able to inspect it by removing the starter...Could also be a worn out engine having too much end play in the crankshaft, letting bolts on the flex plate contact the bell housing.
    • Thanks, so being a different beast altogether, anyone know what the "optimal" temp is for the 10L80/90 for proper shifting?
    • How many years have I pointed out every point in that link to the folks here and been avalanched with criticisms and outright hostilities at times? I ran counter to even the great CUSTOMBOSS and Lake Speed Jr and the half dozen experts on YouTube and in the final.....GM, Physics (Stribeck) backs that Grumpy old Bear.    Honestly, I never said a thing engineering hadn't studied silly and laid in concrete during WWII. But I'm old, the information is old and yet, the Laws of Physics are eternal.    Okay there is one exception. I vehemently disagree with their use of the word 'tolerances' when what it meant is "clearance".   The clearance is the distance between two objects. The tolerance is the degree of acceptable variation permitted in that clearance. I.E., piston to bore clearance is 0.004" with a tolerance of +/- .0002" so the clearance is in specification if it lies between 0.0038" and 0.0042". Cutting that 'tolerance in half has ZERO impact on lubrication requirements. Makes for more difficulty in manufacturing.  But a tighter clearance 'MAY'. Depends on finish. Anyway....   It's one of those statements made by people to make themselves look smarter than they are to convince people who are as un-enlighten as they seem to manipulate their behaviors. But hey, the blind leading the blind puts them both in the pit.
    • Out and about yesterday on a long Saturday drive I passed a lot of Shell stations. My preferred, so I pay attention. Lot's of small town Illinois so not six stations in three blocks like the city.    Everyone of them over a radius of say 100 miles had regular at $4.19 but one which was the one closest to home at $4.15. However Premium pricing varied greatly between 85 cents over regular to $1.50 over. I'm not counting the price of the station with the lowest regular so the reference is the same for the remainder and all within the same brand. However the spread discrepancy holds across all brands.     @txab, any thoughts on that?
    • What are your thoughts? The Chevy Blazer relaunch was an epic case of 'lunchbag letdown'. Jeep Wranglers and Ford Broncos stick out like a sore thumb.    The AI photos do not look like a 'retro version', but shrunken Tahoes. Get away from the 'futuristic look'. I've seen two concepts. One had rectangular headlight like a Rivian and the other way too big headlights (similar to a previous non-Wrangler SUV) should include dual round headlights like the early version.   If not this would look OK   At least it has GM styling (albeit the K2XX) A lot of the images floating around look like Bronco IIs or the current Bronco. Looking at the Broncos in my area (central Ontario, it seems to be a mix of 2 doors and 4 doors, 'mall rated' to ones that could go offroad.    I'm sure a AT4 and AT4X RPOs could be outfitted similar to a Rubicon if the braintrust understood the whole offroad scene. Crossing my fingers that if it does see the light that the front air dam/bumper doesn't extend below the center line of the tire...
    • I saw this news earlier this year:   https://theautowire.com/2026/06/12/gm-kills-off-chevys-biggest-silverado-trucks-as-sales-collapse-and-factory-fallout-spreads/
