Question for those with
I am under the impression that the current model Z71's have 46 mm gas charged shocks but they are not Bilsteins.
Is this true?  And if so,does anyone know who makes the current Z71 shock?
Quote: from Kansas Kid on 3:58 pm on Aug. 25, 2001
I'm about 99.9% sure that the shocks on the 99 and up Z71 trucks are Tennecos.
Bingo
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 986 Guests (See full list)
