Built chevy in toyota body
wickedmag
Wickedmag.com is a extreme motor sports magazine, We are in the middle of building a fj40 with all GM drive train. What' s the strangest vehicle with a Gm power plant in it that you have seen.
How about the Boss Hoss motorcycles, they stuffed small and big block V8's in them.
Yeah, 1 of the guys in the refuse department for the city I work for has a Boss Hoss with the 350. That is something to see.
I knew a guy that put one in a 42" cut Craftsman riding mower.
Ran it with "Zoomy" headers. That F###er was loud.
A guy here in town has an old Willys Wagon body transplanted onto a s-10 blazer chassis. It has the Vortec V6 along with the interior from the blazer, including the AC. stereo and push button 4x4.
Our neighbor has one of these bikes. d**n thing's like a Harley on steroids.
This is a long story but I will tell you about a buddy of mine who had a 70 F100 Pickup with a 390 and auto, he had all kinds of hot rod parts on the thing. Headers, carb, intake, even in 74 put in the first Mallory Unilite that I ever saw. Everytime he would go down the road I would take my Chevelle and run off and hide from him and it was stock. So he started asking all kinds of questions about Big Blocks and one day he started driving his dads car every time I saw him. He would never stop and talk to me when he was in his dads car, and one day he came down the road in his truck again and it sounded different, so I took off after him and had a hard time catching him, when I did he was laughing so hard I thought he might run over me, we pulled over and I asked him waht he had done and he just smiled as he rasied the hood to show me his 396 he said if you cant beat them join them!! :thumbs:
