Truck Keeps Popping AC Belts...
Ok, so I've replaced three AC belts on my 5.3 in the last 7-8 months or so. This sh*t is getting to be ridiculous. Does anyone know why this is happening? I checked the pulleys, it doesn't look like anything is wrong, but this last time the belt was split right down the middle, so I dunno. And why did GM make it so that the belt is BEHIND the serpentine belt? I'd expect that sh*t from Ford, but c'mon. Now I have to take the serpentine belt off to put the AC belt on. ARGH! Sorry, it's been a long day/night, and this is not what I needed right now. My rear bumper was bent today also...when it rains, it f'n pours! :thumbs::P:D:banghead::banghead::banghead::banghead::banghead::banghead::fume::fume::fume::fume::fume::fume::fume:
You got more head banging going on in that post than a G&R concert. :banghead:
I feel your pain with it being behind the main belt...So I'll bang my head with you. :thumbs::P:D
I would try a new pulley. I think mine was only about $30, and there are only two bolts holding it on.
The hardest part was convicing the parts store that I even had a second belt on there. They all kept telling me that it only had one belt. I had to take the lady out there and point at it...."Look lady, I aint making this crap up just to make your day difficult, your stupid computer for losers is WRONG!" That was at the third parts store that day.
If the AC belt was in front the compressor would have to sit too far forward.
We would also see tons of posts that said "Why did GM put the AC belt in front of the main belt :thumbs::P I would expect that from Ford"
Halen,
I had the same problem on a 2000 Silverado w/ 6.0l.
I went through 5 AC belts in about 6 months. Change the tensioner twice. First time was aftermarket, then OEM. My parts guy then sold me a belt that was a bit longer. Still plenty of tension. That was 2 months ago, no problems yet.
Hope this helps.
F_L
We would also see tons of posts that said "Why did GM put the AC belt in front of the main belt  :P  :D I would expect that from Ford"
:thumbs:
That's what you get for going to Automaton workers-zone and O'really's :thumbs:
Thanks for the replies. I got the belt changed this evening. I actually managed to find my receipt for the belt that broke, so I managed to exchange it for a new one. Was kind of a PITA this time, but nothing I haven't done before. My alternator is whining really bad now...I think it's going to die soon, lol. So I'm either going to get a heavier-duty 145 amp alt, or run a dual factory alt setup, which would be about 210 amps. I think 145 may be enough though. Yeah Wingnut, I wish I was at a GNR concert! I'll try a new pulley soon, but I just replaced the belt for now. Thanks for the help, F_L, and welcome to the forums!
its going to break in a few months again if you dont address the root cause.
I seem to remember a TSB about this problem, maybe someone will chime in that has access to it.
    CaptainDad
    CaptainDad
  • Who's Online   7 Members, 0 Anonymous, 566 Guests (See full list)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
