Shipping cost on a Denali grille
What gives??? :thumbs:
I found 2 different auctions on Ebay for Denali grilles and both were wanting $100+ just for shipping!! Is the grille that much bigger or heavier? Or am I just running into some over inflated rates?
Since it is oversized shipping isn't cheap, but it should only run about $40-$50.
A lot of sellers take stuff to the UPS store and get charged an arm & leg for them to pack it up. Then they want you to pay for that. BOOO!
Need to know
* dimensions of box / packaging
* actual shipping weight
* Zip codes (both shipper & consigne)
It may be to large to go UPS and may have to go by LTL (yellow, ABF, Overnite freight lines etc)
If I had the dimensions & weight I could run my freight calculators and get true shipping cost
the $ 100.00 posted shipping charge at the e-Bay site says shipping & handling, That would include cost for Boxing and Tape etc.. The size of the box required to ship the grille could be a few bucks in it self IF the shipper does it with quality boxing to protect the grille during transit.
Yes you got to look out for some of the sharks on e-Bay they sell the merchandise cheap but charge BIG $$$$ for shipping & handling.
If you saw the same adds I saw for the Denali Chrome OEM grille not a bad deal IF you lived local and could pick it up yourself and save the shipping charge. I'm looking to upgrade my Yukon to a Denali Grille, But the S&H is putting a damper on it for me.
Yes, that was the same auction = ) I'm thinking of doing my Sierra.
I guess the shipping might be valid but for me I can buy one around the house for not much more than some of the auctions + s/h
The best part about finding it local is you can see it with your own eyes to see if its as good as the seller wants you to think it is.
The local junk yards want $ 250.00 & up for the few I have found that have them and they would not dicker on the price with me. Not worth my time to even go and look at them so I can't say what they even look like.
I have seen a few advertised inserts that are all metal (stainless steel and/or steel with chrome) that are priced atractive. I would like to see one for real to see if it really looks like the factory OEM denali grill and how good the mounting hardware is.
I'm also looking at the Street Scenes race grilles - I like the look of them in the factory Sierra housing. I'd like to see the black chrome in person as well to see how it compares to real chrome and my trucks black.
As for the Denali parts, I'm gonna just start collecting them and when I have everything I'll to the conversion. I have a nephew that lives in Dallas and works for GMAC...so he has some contacts with some big GM dealers down there...Hoping he can get a break on some pricing for me!
I paid $45.00 to have my grille delivered. They need to be well packed to keep them from being broken. Some Ebay sellers keep their selling price low and make money on the shipping because they pay less of a commision to Ebay that way. It is strictly against Ebay rules if you ever want to report somebody.
    CaptainDad
    CaptainDad
  • Who's Online   5 Members, 0 Anonymous, 487 Guests (See full list)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
