Vehicle Guestbook
asilverblazer
So how come on our vehicle's guest book "Guests" can post comments, and derogatory ones at that? I only have one comment and it is to insult a Chevy truck on a GM website. Can we delete comments some how? What a :chevy:
:D
Oh someone with obvious small man syndrome that has to do this stuff to feel "cool" is obviously a sad sad person... :chevy:
At least the comment left in your guestbook is only about Chevy trucks, the one in mine is completely uneccessary. I PM'ed the webmaster to see if he can remove it. I dont think guests should be able to post comments! Its always the few assclowns that ruin it for everyone.
Mike
I deleted the message in your guestbook for you...
stupid asshats with nothing better to do... :chevy:
Will have to see if Mervz can change that setting or not...
You can add a vehicle to your garage (see the link at the bottom of your post labeled "garage") and then you have a guestbook that people can leave comments in. :chevy:
Yeah I noticed that. I alerted the admins and they are looking into it...I would delete all the asshat's comments, but there are too many and I don't have that kinda free time...
Seems strange that members don't post comments. Maybe it's the front page to the garage... it shows the id's of the members who posted the last 10 comments.
They were all blank after he :cheers: did his dirty work.
Is there any way to see all of the recent comments beyond the last 10? I'd like to read all of the :D comments, just to get a feel for the miserable personna that did all that.
