Deisel exhaust
well I got rid of my 2000 GMC 1500....and just picked up a 2005 Chevy 2500HD duramax/allison LT 4wd crew cab......LOVE IT!!!!
Just wondering which exhaust to go with.....which will give the best performance and sound?? any increase in MPG? can you hear the turbo more w/ exhaust?? ( I love the whisteling sound of the turbo :) ) .....I was looking for the full cat back system and thinking between 1. RBP (rolling big power) 2. Magnaflow and 3. Banks. anyone have any experience whith these or any recomendations.....???
thanks.....
Just wondering which exhaust to go with.....which will give the best performance and sound?? any increase in MPG? can you hear the turbo more w/ exhaust?? ( I love the whisteling sound of the turbo  :cheers:  )  .....I was looking for the full cat back system and thinking between 1. RBP (rolling big power) 2. Magnaflow and 3. Banks. anyone have any experience whith these or any recomendations.....???
thanks.....
Congrats on the diesel.
Of your three choices, I have only heard the Banks system from inside and outside the truck. Not knowing what you consider loud; I personally thought that the Banks was too loud for my taste – and I don’t mind a strong sounding exhaust.
I can tell you from experience that the Quadzilla 4” and MBRP (DPI) 4” sound great. Quad offers you two different mufflers to choose from, and both Quad and MBRP are almost silent at cruise and aggressive during hard acceleration.
The only thing that I really noticed from my 4” exhaust was a about a 100 – 150* reduction in egt’s which is a really good thing. I notice the turbo more in my Ford than in the Chevy – both trucks have 4” aftermarket exhausts.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
