A/C filter
Jeffrulz21
Does anyone know where is the location of the a/c filters for a 03 silverado? The dealer said my truck has them but I can't find it anywhere. There is a place under the dash on the passenger side that looks like it might be the spot, but it doesn't have anything in it or a way to hold a filter in place. Any help would be appreciated.
"Starting in 2003 model year, the passenger compartment air filter is no longer available as a factory option. With the redesigned HVAC case, there is no longer a cavity for the filter. The GM parts catalog indicates there is a replacement filter available; however, there is no provision for it. "
Thanks for the information, I will take the $58.00 filter that I got from the dealership back. Thanks Again!
