are add ons to base radio possible?
I've been searching other posts for a solution, but have not found a definitive solution. The problem is...can I patch in other audio input sources to a base 2004 radio,no CD,XM, or cassette (no theftlock). I have tried to use a wireless FM modulator to listen to cassettes( I have 500 or so), and CD's, and later would want to add satellite radio too. The wireless FM mod is noisy at best on the open road, and doesn't work in town at all.I am considering adding a wired in FM modulator( inline with the radio antenna ), but some posts seem to warn that any external tampering will require a trip to the dealer for re-programming. All I want to do is to hear less commercials, more music that I've already paid for, and not have to spend more than $100.All my spare cash goes to my Chevelle bracket car.Can anyone help me here?
The base radio has no inputs or capability to add extra options, your best bet is to use the FM modulator or upgrade to a upper level headunit.
All of the other stock headunits have the input and are XM ready.
Have you considered just getting one from a salvage yard? I would think you could get a OEM unit that will just plu in and have more than the base capability . . . I suppose I could be wrong however . . . maybe the junk yard will charge more than $100? I'd at least call them. Also, there are a ton of people who buy trucks and replace the OEM system . . . check eBay or your local paper or auto stereo shop and see if you can get one. Most of the time they are just tossed anyway . . . I would think you could steal an OEM unit with extra features . . .
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • Checked the pads today and there's plenty of meat on them. If the message keeps coming up, I'll just answer YES that the pads were replaced and wait for the squeal.
    • Welcome to the Forum! Always post the code definitions along with the codes. there are over 18000 possible codes, no one remembers them all and most will skip over your post rather than look them up
