Tire Size
cdiddy
Have a 2001 1500HD, not sure what the stock size is but when I got the truck it had 265 on it. Just put a body lift on and went to a 35-12.50-17 tire. I think the stock tire size was 245-70-16. My question is do I need to recalibrate or flash the computer?? And if so what exactly will that do???
Having the proper tire calibration will mean your speedometer will register accurately, your trans will shift at the appropriate time, etc. ABS should be recalibrated to and this is in a different area. Calibrating the PCM does not do anything for the ABS.
I changed tires of my 02 1500HD and used my Hypertech Programmer to re-calibrate for the difference. Unlike some programmers, my Hypertech asks for tire measurements rather than size. This make it more versatile IMHO.
