Stronger Drivetrain?
My truck is mostly on the road but when i do hit the mud i want to have something that won't break on me..such as stock axles, etc. In the rear I have and aurburn locker and the 4.56's but as far as axles what do I need to hold the stress of 40's. In the front what kind of axles do i need to keep from snapping like stock ones.. that's if i keep an IFS.. and if i do convert to a straight front axle I am gonna put a d60 in it... need suggestions!
40's and your stock drivetrain will not go well together!
For the rear:
Either a 14 bolt FF or SF out of a chevy truck. The Full-floater is the bullet-proof axle of them all. It has a 10.5" ring gear, you can put gears as low as 5.13 in it. The only downside to this axle is the large center section leading way to low ground clearance. The Semi-floater is a 9.5" ring gear and only goes to 4.56. It's more expensive to build, harder to find, and inherently weaker in design. Get a 14 bolt Full-Floater. They can be found in 3/4 and 1 ton trucks from '73 up to the HD era of '02. If you get one out of a 1 ton truck, it should swap in without needing to move spring perches. However, you're better off getting one that you do need to move the perches for so at the same time you can adjust your pinion angle for the lift. Oh yeah, and the 14 bolt FF comes with an open of a gov-lock limited slip differential. If you get one with a gov-lock, it can not be outfitted with a Detroit locker. If you get one with an open carrier, it can easily be welded, spooled, or locked. Don't pay more than $250 for a 14 bolt FF, they're abundant.
For the front:
IFS is out of the question at 40s in my opinion. It's iffy at 38s on the street...let alone 40s offroad. The best option for you is the Dana 60. Your truck has a driver's-side drop transfercase so you'll need to get a Dana 60 from a Ford truck. While you're at it, get one that has reverse rotation so your pinion is higher off the ground for better clearance. Get ready to shell out $1000-1500 for a Dana 60 of any type.
And, with your new 8 lug axles, it's time for new 8 lug wheels.
If you go with the 14 bolt FF and hi-pinion Dana 60, you'll have the bulletproof drivetrain any off-roader will respect/drool over.
-Steve
:cheers: What he said. :D
The only non OEM axle I have heard of is just now being offered by rough country. Doubt it'd handle 40's though.
Also keep in mind that you are in a 1/2 ton "light duty" truck and you're putting in some heavy gear. One shop told me that these frames aren't really meant for this type of stuff.
The frames will be able to handle heavier duty axles...that's all unsprung weight. However, what this shop was probably getting at is that if you put 3/4 ton or 1 ton axles in a half-ton truck, that does not mean you can now haul as much as a 1 ton truck.
ANYTHING CAN AND WILL BREAK GIVEN THE RIGHT SITUTATION. IF YOUR IN THE MUD A 60 f&r SHOUDL HOLD UP, BUT i WOUDL GIVE DYNATRAC A CALL AND UPGRADE TO THE 35 SPLINE SHAFTS. MAYBE EVEN GET A HP ROCK JOCK 60 WITH THE ALUM CENTER.
OR GO WITH MOG AXLES OR ROCKWELLS. OR A MOG 9.
DO SOME HOMEWORK YOURSELF , AND THEN YOU CAN ANSWER THESE QUESTIONS YOURSELF.
This is part of his "homework" I would imagine. :D
    TopBo
    TopBo
  • Who's Online   4 Members, 0 Anonymous, 1,185 Guests (See full list)
    • Can anyone explain why the oil pressure runs higher after the DFM is shut off?  just installed the Pulsar Lt.
    • Thanks!  I figured as such; GM and other manufacturers have used standard parts and harnesses across trim levels and such for decades.  I pulled the blank accessory cover off of my commuter van (a 2016 or so Chevy 15-passenger) years ago and found the plug for a USB outlet.  It wasn't connected to anything, though (I tried swapping in an outlet from another van).  I was a GM Tech years ago (late-90s) and was pretty familiar with my 2006.  I might be wrong, but I view newer vehicles (pretty much anything made in the past 20 years) as being a lot more plug and play.  Meaning, more unused wires and plugs unless you have the Mack Daddy of vehicles.
    • not all plugs will be used.  gm uses more generic harnesses that support most/all options, and if your truck doesn't have a specfiic option, the plug won't be used (commonly will have a dummy insert in the plug , or it'll be taped up, but some may just be left as is).  But it's sldo possible some p.o. has installed the wrong/cheaper parts that aren't correct for your vehicle...
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
