Wiring Foglights To Come On Automatically
I'm sure this is the same on the other late Envoys. At night, I have to push the FL button for them to go on. Anyone made it so they come on automatically?
take the hot wire and wire it directly to the parking light hot wire. Whenever the headlights flip on they will come on also. I did this with my 2500hd and the neighbor's envoy xuv.
