FS: '02 2500HD
'02 2500HD, 35K, ext. cab, pewter, 6.0L, plow prep package, 4.11 gears, bedliner (like new), tonneau cover, new style silverado tail lights, remote start, 285/75 ProComp allterain tires, new premium rotors and pads installed frnt & back 3 months ago. Truck is immaculate, never plowed or used for work! The most it pulled was my 2 snowmobiles. $18,900
[email protected]
315-436-3095
    • Correct.  2019-2020 are serviced by a different p/n.  19420611.   The recall engines 2021-2024 are serviced with 12740076.     What the difference is between the two, I'm not sure, but 2019-2020 only show 19420611 as the replacement engine p/n.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
