Any foreign members here?
MadFish
Anyone?
I've been seeing a lot of trucks around here in Germany. Dont know why :seeya: Trucks arent very popular around here. All I have seen so far are single cab 1/2ton Chevy and Dodge trucks.
When I was stationed in Germany you could count on one hand how many fullsize trucks were around and still have a few fingers left. There was one guy who had a Z-71 and between the gas prices and driving thru some towns that had narrow streets it made it a challenge. He also said that since He had his truck shipped to Germany it voided the extended warranty he got from GM.
Yeah, the warrenty goes bye, bye! I was going to bring my 2005 Mustang GT with me when I moved here. BUt, I would have lost the warrenty and I didnt want to have to fix the problems that might come up with it on my own. PLus, it would have cost about $3k ot ship it over here and get it to pass the German vehicle inspections. Im on a tight budget as it is. Add a gas guzzling Mustang and I'ld never make it.
Im here in Germany for as long as I want. But, I'll be here at least 2 years. My fience(or however its spelled) has 2 years left at the school she's going to. After that we'll either move back to KC or somewhere else.
No, I never got it done. I got it closer to being finished. I got all the body work done and all the major stuff. but, sadly I had to sell it. I needed the money. I was going to sell it and keep my Mustang. But, I couldnt afford the Mustang over here. When we get back to the US or to where ever, Im definetly getting another one. I loved that car. Never had a Mustang before that. But, I caught the bug.
