Where is the o2 sensor
HDboy
IT SHOULDN'T BE MORE THAN 6 INCHES FROM REAR OF CAT. ON THE RIGHT HAND SIDE OF PIPE OR BETWEEN THE PIPE AND FRAME RAIL IF THAT MAKE SINCE TO YOU
NO, I WAS NOT AWEAR THEIR ARE 4 O2 SENSORS ON THE PASSENGER SIDE PIPE BEHIND THE CATS  :cheers:
The original post stating this did not go into enough detail. There may be 4 sensors, but they are not all in one spot! You only have one sensor behind the catalytic converter. If you have two catalytic converters, you have one behind each, making a total of 2. Then you have one in each side ahead of the converter, making a grand total of 4.
