Rate Your Dealer
Good Day All,
I found this link, Rate Your Dealer, on another site. Here is a forum to report good and bad experiences. I just thought it might come in handy, especially in today's climate of good and not-so-good customer service.
Cheers!
Autumn
Wow...that's useful...... It only shows about 20 dealerships for the entire state of OK.  They are all in OKC and Tulsa.
BOOO
Well...Why don't you hop on there and make it 21 then? :seeya:
:sigh:
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
