Temp Gauge keeps climbing
LVQuad
Hi all,
I had a problem show itself today. I was doing some running around town today and noticed the temp Gage riding steady at about 220 degrees. The outside temp was 99 degrees. After I stopped at my first stop I came back out to continue my errands and the temp gauge read about 240 degrees now. I didn't notice any unusual characteristics so I continued cautiously to my next stop. Again I came out and started the truck and now I was at 265 degrees! No overheating, no pinging, no lack of performance, all seemed normal otherwise. after returning home I let the truck sit for about 1 1/2 hours and came out to check it and started it up and it still read about 245 degrees.
Does anyone have any suggestions what might be making the temp gauge act like this? The other gauges are all reading normal readings. Can I reset the gauges by unplugging a fuse or something?
Thanks, Eric
P.S. The trans temp guage never went above 195 (normal).
Hi all,
Thanks, Eric
My 2000 silverado with a 5.3 in it has done this as well...........but only when its been really smokun hot hotside and I have had my aircon on and sitting in traffic.........it didnt overheat but the temp gauge git pretty high up in the scale..........I dont think there is much I can do in ther conditions I described.............sounds like the same happened to you. :driving:
Eric, wasssuppp ?!!!!?
What the heck happened ?!?!?
Maybe a sensor failing ?? Did it *seem* hotter than usual, or just according to the gauge ??
The trans temp staying normal kinda makes me think maybe it's just a sensor or gauge bailin' on ya :driving:
But... ummm..... I'm no GM Expert :P:D !!!!!
If it was really over 260 degrees, that coolant would be percolating in the recovery tank and the engine would be rattling, etc. Sounds like a gauge problem.
No, there's no resetting of the guages.
Thanks guys.
I kind of figured it was a malfunction somewhere. The gauge now reads somewhere around 280-290 degrees and its cold!
I guess its off to the dealer.
Thanks again, Eric
    • Hey everyone,   For anyone looking at roof-mounted lighting for the Hummer EV, we wanted to share our M&R Automotive 50" PRO Roof Light Bar for the 2022+ GMC Hummer EV.   The curved 50" bar sits close to the windshield rather than sticking way up above the roofline. The mounting position is designed to keep the setup relatively streamlined while minimizing wind noise and maintaining full use of the factory windshield wipers.   A few details:   50" curved PRO light bar Fits 2022–2026 GMC Hummer EV Spot + driving beam pattern TIR optics White main beam Amber DRL backglow Approximately 15,410 measured lumens through the lens Mounts to factory accessory locations No cutting or drilling required Wiring runs down the A-pillar toward the AUX connections Designed to minimize wind noise Lifetime warranty Off-road use only     The 50" is an interesting middle ground for anyone who wants the visibility and mounting position of a roof bar without stepping all the way up to the larger 60" setup. For the Hummer EV owners here, would you go with the 50" for the lower-profile look or step up to the full 60"?
    • My son got a hatchback withe the aero package for like 17k new. Great little car with amazing MPH
    • Yeah, I've given up years ago with that! I was able to load a few when I first joined the site sometime around '07. Then after maybe 20 pics, it said I exceeded the limit. Now every pic I try to post says I've "exceeded 1mb".   ONE MB??? That's Windows 95 ******, lol!!
    • I get the same results with pictures. Then I figure it out. Then I forget. Screw it.
    • I guess I'm the only one on this forum who can't get effing pics to load here! Do you have to resize them to post, or am I just blocked from uploads?   I have the same luck with automotive electronics ... but this is the ONLY site on the net that I have this problem!   I'd post pics of what I'm working on ... but I CAN'T! 🤬       Just fabbed up the kickdown cable (had to extend the cable mount WAAAY out from the throttle shaft to get a full pull), and parts arrived for the fuel lines on the 940 carb conversion project. Should be able to drive this thing by the end of the day. If not for work, I'd have had this thing done SIX weeks ago.   Got the jetting sorted out last week. Had a real bad tip-in bog that I couldn't seem to correct. Friggin float height was over 11mm too HIGH! eBay purchase, so no wonder everything is screwed up right out of the box! I ended up with a larger dual-squirt accelerator pump jet anyway instead of the single. Also moved the 70 primary idle jet (4 sizes too big out of the box) to the secondary idle circuit, and installed a 57 in the primary. Runs great on the fuel bottle!    Still using the computer for ignition. Going to drive it first and see if I want to go through the project of installing an intermediate shaft with a distributor drive gear, so I can install a block-mounted distributor and run points, 100% computer free. I should do that anyway just from a simplicity / reliability / tunability standpoint. The electronics left me stranded last year a couple times! I can't tweak the timing to my liking right now because of the computer. Tried twisting the cam-driven distributor already ... and the damned thing just reverts back to where it was! That's infuriating. But if it runs well enough I might save that for next season.   Just driving it in and out of the shop to work on other projects, it feels 1,000% more responsive with the carburetor. Also fires MUCH faster when cranking. Can't wait to drive it and see if I got more than 114 ponies, lolol.   Hopefully these don't go 404 like the last post ... https://postimg.cc/gallery/MjhrmZS   Seems like that site went back to dial-up internet! Maybe they'll fix that some day ...
