How to give a cat a pill...
Scyry
How to Give A Cat A Pill
1) Pick cat up and cradle it in the crook of your left arm as if
holding a baby. Position right forefinger and thumb on either side of
cat's mouth and gently apply pressure to cheeks while holding pill in
right hand. As cat opens mouth, pop pill into mouth. Allow cat to close
mouth and swallow.
2) Retrieve pill from floor and cat from behind sofa. Cradle cat in
left arm and repeat process.
3) Retrieve cat from bedroom, and throw soggy pill away.
4) Take new pill from foil wrap, cradle cat in left arm, holding rear
paws tightly with left hand. Force jaws open and push pill to back of
mouth with right forefinger. Hold mouth shut for a count of ten.
5) Retrieve pill from goldfish bowl and cat from top of wardrobe. Call
spouse from garden.
6) Kneel on floor with cat wedged firmly between knees, hold front and
rear paws. Ignore low growls emitted by cat. Get spouse to hold head
firmly with one hand while forcing wooden ruler into mouth. Drop pill
down ruler and rub cat's throat vigorously.
7) Retrieve cat from curtain rail, get another pill from foil wrap.
Make note to buy new ruler and repair curtains. Carefully sweep
shattered figurines and vases from hearth and set to one side for
gluing later.
8) Wrap cat in large towel and get spouse to lie on cat with head just
visible from below armpit. Put pill in end of drinking straw, force
mouth open with pencil and blow down drinking straw.
9) Check label to make sure pill not harmful to humans. Apply Band-Aid
to spouse's forearm and remove blood from carpet with cold water and
soap.
10) Retrieve cat from neighbor's shed. Get another pill. Place cat in
cupboard, and close door onto neck, to leave head showing. Force mouth
open with dessert spoon. Flick pill down throat with elastic band.
11) Fetch screwdriver from garage and put cupboard door back on hinges.
Apply cold compress to cheek and check records for date of last tetanus
shot. Apply mouthwash to cheek to disinfect. Throw Tee shirt away and
fetch new one from bedroom.
12) Call fire department to retrieve the cat from tree across the road.
Apologize to neighbor who crashed into fence while swerving to avoid
cat. Take last pill from foil-wrap.
13) Tie the little creep's front paws to rear paws with garden twine
and bind tightly to leg of dining table, find heavy duty pruning gloves
from shed. Push pill into mouth followed by large piece of steak filet.
Hold head vertically and pour 2 pints of water down throat to wash pill
down.
14) Get spouse to drive you to the emergency room, sit quietly while
doctor stitches fingers and forearm and remove pill remnants from right
eye. Call furniture shop on way home to order new table.
15) Arrange for SPCA to come get the cat, and call local pet shop to
see if they have any hamsters.
How to Give A Dog A Pill:
1) Wrap it in bacon.
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAmen
