Jerky Power Steering
When i'm turning at speed somtimes the truck will over power assist with power steering causing me to abruptly jerk into the turn more. It is really annoying. Does anyone know what causes this? It is full of fluid, looks to be atf, or some other red power steering fluid.
It adjusts the power assist for different speeds, I can't remember the fix but someone will know, it's becoming a common problem. Have you tried the broken search?
It would help if you gave us the year make and model.
I will tell you that from about 98 up, there is an EVO sensor that calculates the rate of turning the wheel and adjusts power steering power accordingly. It is a donut like thing around the steering shaft above the brake pedal. You can replace it or some have had success blasting it with WD-40 between the donut and the steering shaft.
This is a common failure and is possibly the problem but a loose front end could cause similar symptoms.
my dad has this problem too, but he had a 97 yukon. at highway speeds if you were rounding a corner, the steering wheel would jerk a little. it was annoying.
ya, its a 97 gmc 1500. So that evo thing is at the base of the shaft inside the vehicle? and can it be repaired with some quick fix or does it have to be replaced and if so how much are they and how hard is it?
This photo is from my 1999 K1500 P/U (OBS) so it should look fairly close. The red arrow is the EVO sensor, the yellow arrow is the electrical connector:
what happens if you just unplug it?
You loose variable assist in the steering and it probably sets a code(SES). I know you can disconnect it for testing but I'm not sure I would want to keep it that way.
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
