volume sensative mic Question
5strinz
OK...I thought I needed to buy the mic, but now I am not sure.
I found a mic in the headliner right above the driver. The mic screen is obvious and there are wires running to it - Green, WHite, Brown , and Black. I am thinking that is the mic for volume adjustment on the nav HU. Or...is it a mic for Onstar. I don't have Onstar (Could it may be installed anyway?).
Question 1 = is this the volume operating mic?
Question 2 = If it is, where do I find the appropriate wires by the amp to plug into the amp C1 conmnector at B1 slot?
Thanks in advance,
Dave
'04 Yukon XL
TNR (self installed)
NO disc changer
no XM
That is the onstar mic, the SCV mic is located i beleive in the center console.
Thanks, that was what I was thinking till I saw this post by trustworthy BBSILVERADO:
QUOTE The mic clips on the drivers side of the overhead console. The two wires go to the Bose amp connector (24 pin connector) the dark green mic wire connects in the B1 position and the ground goes to B2 or B7 (both are the same) UNQUOTE
That got me wondering. Dave
For the Speed Sens volume, i dont believe there is any mic for that.
SCV is ONLY speed dependent based on the speedo, there is no mic that senses road / wind noise. If there were, your radio would go nuts every time a Harley went by!
I am now confused :confused:
The following is the designated pins for the amp connector. Notice that B1 is desigated for the volume compensating mic.
QUOTE:
Here is the wires that need to be moved in the 24 pin connector to go from a non-lux amp to a lux amp.
A1 - do nothing
A2 - do nothing
A5 - move to A4 (brown wire)
A6 - move to A3 (yellow)
A7 - move to A8 (dark blue)
A8 - move to A7 (light blue)
A9 - move to A5 (tan)
A10 - move to A6 (gray)
A11 - move to A9 (light green)
A12 - move to A10 (dark green)
B1 - cap off, not used (gray/black)
B2 - cap off, not used (purple)
B3 - cap off, not used (black)
B4 - cap off, not used (dark blue)
B5 - cap off, not used (dark green/white)
B6 - cap off, not used (brown)
B7 - move to B3 (orange/black)
B8 - move to B6 (light green)
B9 - move to B4 (dark green)
B10 - move to B5 (tan)
B11 - cap off, not used (pink)
B12 - move to B7 (bare wire)
Add data bus wire from B1 (small orange wire) on the headunit 24 pin connector to B10
Add microphone wire to B1 (optional, but recommended for the sound compensated volume to work)
UNQUOTE
Per this...there must be a mic for volume compensation. I purchased GM part #15240415 - a microphone. It is plugged into the B1 and seems to work. I would like to see it work better....or even confirm it is working correctly.
dave
    • Would you supercharge the 6.2L on a 2021 GMC Yukon Denali XL with ProCharger?.... 605HP is the stated number without going crazy - it's not the LT4 682HP package, but I'm tempted to install it... This vehicle was ... not... recalled on the engine swap - but I don't really know if that means ...don't do it... or do it;)    Maybe i should start a prediction market pool on it in case it blows up;)   Any thoughts appreciated - I already OWN the supercharger - stopped the installation when the recall was announced and now it's taking up space in storage until I can solve an electrical issue with the vehicle...  4th GMC suburban-equivalent truck - I like them a lot - when they don't a) discharge their batteries randomly, or b) throw a rod at highway speeds;)
    • We tested the sleep mode with an ammeter in series with the negative battery terminal - 30amp fused - so we do know the actual shutdown and non-shutdown current draws and timing of the shutdown sequence.  We just have no protocol information to determine what module is issuing the network keep alive.
    • TrueBlue...Even if you don't have that info stuff displayed, If Mr. Computer thinks there's something you should know about, it will pop up a warning message no matter what else is being displayed. I keep the speedometer displayed all the time, yet the brake pad message pops up anyway.
    • BTW, the 11.5amp draw is all the usual systems active - it's not a single draw - that's the "we're all awake" state of the vehicle - forinstance if the power steps are actuated, the draw will spike to 22amps for that operation.  when the battery is disconnected and then reconnected, the vehicle shuts down that one time only - and we see a 10-15minute progression down 11.5  10.5  9. 8 6. 5. 1.6... 500ma... and then off to sleep at 40 milliamp... as expected.  So we know it's a module that is simply refusing to allow the SDGM to proceed to the sleep state.  We do NOT think it is the telematics VIM module - since we already duplicated the problem with the "VIM bypass" solution installed (we reverted that since it also disables the gmc app - but it does not appear that the telematics system is the culprit).  We've replaced the rear heater control module, tested without the wireless charger, and the other modules on CAN Bus 5 - but still something is keeping us awake and removing X2 from SDGM allows sleep to proceed.  We cannot diagnose from OBD since OBD drops off at about the 9volt level in sleep mode and we can't communicate with the vehicle - also we can't trace the SDGM internal packets from the OBD side - we have Autel Ultra.   Any ideas on why disconnecting X2 would allow sleep to proceed appreciated.  This is no longer a repair situation - this vehicie is simply unusable in this condition and NOBODY at GMC Dealer can even understand what it is doing.  This is crazy.  We made these systems too complex and now we're paying the price.
