Nav radio doesn't like my wife!
s-t-p
This story is actually started in another thread, but I wanted to move it to its own topic.
I installed a nav radio I purchased from eBay in my '03 Escalade. The install went well except for some initial weirdness after deactivating the theftlock but then the unit settled into working fine. Then my wife came home one day after using the Escalade and said the radio wasn't working. The navigation was still on but there was no audio. I drove it for a while and sure enough, the radio didn't work. I tried resetting the unit by pulling the fuse and the audio came back on and everything worked fine. My wife used it next and sure enough, the audio had gone out on her again. I reset the nav radio again and it worked fine again.
We could not figure out what was going on. My wife was not even using the radio when she drove. She hadn't touched a thing. But sure enough, the next time she used it, the audio went out again.
Then it occurred to us, could it be her keys? The only thing she was doing was using her own set of keys. I went out and reset the radio pulling the fuse but with her keys in the ignition. The audio didn't work. I then reset the radio with my keys in the ignition (we had also used the key fobs to unlock the doors before doing the resetting). When I reset the radio using my key and fob, it worked fine. When it was reset using her key and fob, the audio would not come on.
Has anyone heard of anything like this happening? When the nav radio had the theftlock deactivated, did it only recognize my key and fob now? Is there some way to fix this, like maybe the dealer reprogramming the radio so it recognizes both sets of keys and fobs?
:cheers:
Does the radio have anything to do with personalization on the Escalades? In other words, with the old radio did the presets change, or the station you were listening to, when you used your fob vs. your wifes? I'm just wondering if the personalization feature is throwing things off. Is this the INR (joystick) or the TNR (touchscreen)?
As far as I know, there was no radio personalization. There is seat, mirror and environmental personalization, but I don't think there was any radio preset or other radio setting personalization. Could be, I just don't know for sure. I could try to check and see. It is an INR, not a touchscreen.
My 03 Burb does have personalization on the radio depending on which key fob you use. I still don't feel like that is what is going on but I have seen stranger things
I took a closer look at what was happening when using my wife's keys and fob. It isn't just the audio that goes out. The navigation is still on but the screen is not a normal appearance (the picture is sort of "askew"). There is still no audio, but if I push the BAND button. a blank screen comes up. After a few minutes on, the FM screen does come back on but I cannot change the stations. The audio never comes back on until I reset the unit by pulling the fuse.
Everything works fine if I use my keys and fob.
  • 1 month later...
:dupe: I HAD THE SAME THING HAPPEN TO ME....I THOUGHT THERE MAY HAVE BEEN A MUTE BUTTON PRESSED BY ACCIDENT MY HUSBAND UNPLUGGED THE SAME RADIO FUSE & IT WORKED JUST FINE & THEN IT HAPPENED AGAIN WE ALSO THOUGHT IT WAS THE KEYS...DID YOU FIND OUT WHAT WAS CAUSING THE PROBLEM??
    RyGuy43
    RyGuy43
  • Who's Online   5 Members, 0 Anonymous, 463 Guests (See full list)
    • This is NOT impact damage nor neglect. There were previous class action lawsuits because of such paint preparation st GM manufacturing plant. Not just the Cherry Red Color. This paint is applied in three processes to obtain the desired color.  The manufacturer will cover for 36 months or 36k miles only. That rust is actually corrosion because of the paint process failure. Corrosion is covered for 100,100 miles or a certain months. However their corrosion doesn't include this type. Go figure. Clearly manufacturer knew from previous paint issues. This started 3 weeks ago out of the blue.
    • Is it time to put a piece of tape over the CEL?
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
