Brake light warning
My wife tell me last week going to store and notice the yellow ABS and Red Brake light was on no tble stopping went inside- and out drove home no light . I drove for abot 4 days not able to get happen. check a good one over. and did abrout stops in a parking lot frd, and rev all looks good no leaks or anything.
So Today driving from wife job both lights, come on able to brake normal ???
anyone have this type of problem??
Jimmie
i'm a it confused by the story and the situation you have but i see that you have a problem on the ABS and the brake lights. it may be a good idea to sacn over the computer to know the faulty codes your car has. the ABS lights up when there's a trouble on your braking system. it's also best to check it with a trusted mechanic.
hope this helps.
hope this helps.
got truck back today the problem is EBCM relay had a short. replaces 890.00 later cover under warranty. a good thingecbm electronic brake Module. now ride and brakes better now
