cat converter removal
Question to the GM gurus,
When running duel exhaust on my 03 2500 HD 6.0, can the cat converters be removed
without any problems with the trucks computer, or will it throw codes due to altering emissions stuff? I know w/out the converters the motor should breathe better and maybe wake up a little, anyone done this yet?
well you douches went out of your way to avoid his question, any way man you can cut them off but it will throw a code. Get a set og O2 simulators from Casper Electronics, you can cut them off with out the computer freaking out if your running those
No, actually they didn't. If you would have payed attention to the initial post and the following responses, then you would have seen it. I am sick and f*cking tired of people not reading posts, and then blurting out some profound statement that they think is so cool. :confused: Below I am going to point out that his question was answered and your a dumbass for making your post.
Question: When running duel exhaust on my 03 2500 HD 6.0, can the cat converters be removed without any problems with the trucks computer, or will it throw codes due to altering emissions stuff? I know w/out the converters the motor should breathe better and maybe wake up a little, anyone done this yet?
Answer 1: you're going to get codes from the rear O2's. there is little to no gain in removing them, i have no idea why you'd do that.
Answer 2: The newer cats. are high flow and unless you increase displacement you will never need larger cats.
As you will clearly see, the first question he asked was answered. "The vehicle will throw a code from the rear 02's." The second question was answered in a different form. "There is no need to remove them, the new model converters are high flow". "The newer cats are high flow and unless you increase displacement you will never need larger cats." They are trying to tell him that there is no need to remove them and it would be a waste of money. Last but not least, 02 sim's suck balls. Research s**t before blurting it out.
Next time read the post, analyze it, and then type your response. :banghead:
Whoa dude, a little harsh. Why the attitude? They have sex with your sister or what?
And let's not forget that it is highly illegal to remove the cats.
And Meatywand is also the person that in an earlier post couldn't figure out where to put O2 simulators on his own truck:
O2 Sims
:banghead:
O2 Sims
:banghead:
Illegal never stopped anybody. So that throws the legality bit out the window. If you have to pass a sniff test in the state your truck resides, dont do it. Yes it will set codes, the rear O2's will get whacked. Get O2 sims or have the rear O2's turned off with a tune. You may gain some up high, nothing drastic and no real gain down low. Exhaust may get raspy depending on the muffler being run. There really is no need for true duals either on a stock truck. Unless you really feel like blowing some cash.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
