I need a horn like this.
Wingnut
Yeah, that was hysterical. It kinda reminds me of the 87 Jimmy that the last department I volunteered for had. That thing sounded like an early 80's GMC school bus horn.
    flyclt
    flyclt
  • Who's Online   5 Members, 0 Anonymous, 636 Guests (See full list)
