Lug Nuts
Question kinda sums it up. After all my recent tire drama, the shop that was balancing my tires rounded-off my wheel nuts & having rounded nuts is a bad thing IMO :crackup: . SO, after I get some new ones, which size wrench (more specifically socket) are you guys using? Any particular brand/type that seems to get a real good bite?
Thanks
Edited to add sad rounded nuts face.
I use a 22mm 6pt socket and 1/2" breaker bar.
The more pts the socket has the more likely it is to slip and round off the nuts.
The socket doesn't cost much so don't go cheap and buy off brand garbage. Get a Snap-on,Craftsman,ect.
Dont know how often you are going to be changing the lug nuts, but driving awrecker I can tell you that one of the best tools I have for lug nut removal is a 4 way lug wrench that is all one forged piece, the 2 piece ones that are tack welded together dont last, and I have broken sockets useing a breker bar before. Just my 2c
Where can I get a one-piece 4 way wrench? The only ones I've ever seen are the cheapo tack weld jobbies....
Thanks
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
