Raylar/PCM/questions
Hello, I have a 2003 chev K2500HD with the 8.1/Allison - 4.10 locking rears. I am interested in the Raylar 1.8 ratio rockers for now and then adding the heads later. Will the rockers work with a stock motor with stock heads and a stock PCM. Also will I be able to get the PCM customized to benifiet even more from the rockers? Currently I have a Volant intake and a Flowmaster exhaust. I have a Diablo Sport Programmer now but I am trying to decide between the Westers tune and the Wait4me tune. I was just worried about piston to valve clearance and valve spring binding with the use of the 1.8 ratio rockers. Please help with these concerns as I am looking to increase HP and towing ability as well as squeeze a little MPG out of it. Thank you for your time.... Ryan.. :nopity:
yes u can get the rockers to work with the stock heads i think that u have to buy a stud kit
im not sure about the programing for the rockers but i know any good tuner will tune it to maximise your engine
hope this is what ur lookin to hear
No mods needed to run Raylar rockers. The stock springs are weak but with a stock cam you should be fine.
I was running Comps biggest cam listed in their book with 1.8 rockers.
