Squeeky sterring wheel?
I found out that i wasnt the only one with this problem.
I know of at least 3 others with this stupid, annoying, problem.
This was the fix that i hope to try in a little while:
Look at the bottom of the steering column right above the brake pedal. Where the column exits the cab. There is a rubber boot that the column goes through. Mine touches on one side and every so often starts squeek. Put a little grease on it and it'll take care of it.
