Dirve shaft?
I got my truck lifted about 3 weeks ago and I am hearing a poping sound that i think is coming from my drive shaft . I've got an '01 Z 6" fabtech with 35" bfg m/t. I have still got my factory drive shaft. Has anyone else had this problem? It is not a big deal it only happens when I am at a complete stop and I begin to accelerate. And it is just one pop and then it is fine. Is it just due to the angle that the lift puts on the drive shaft? Thanks.
Yes, I have it too. It is a very common problem, even with some factory height trucks. It's mainly due to axle wrap caused by the lift blocks. It causes the rear axle to move front/back causing the slip yolk to move. When you take off, the slip yolk slaps the transfer case a bit, causing the noise. Sometimes when you take off your slip yolk and grease it, it will help. It only helped me for about a day. They also sell a nickel plated slip yolk that was part of a TSB that stops it. The real solution for a lifted truck is either traction bars or even better, lifted leaf springs.
  • 3 weeks later...
I'm sure any dealer can get it for you. I don't know the part number though. I just really greased mine a couple weeks ago and it's been quiet ever since. I don't have the nickel plated either.
the grease only last a day or to for me
    • Which one, the AT or AS?   Starfire is made by Cooper/Goodyear but at $85/tire I'd think I'd need to level-set my expectations that they may not even be round 😉 But you're saying they're decent?   I'm already into this thing $1506 in parts, fluids, etc. Totaled all my receipts today. $250 of that was replacing an EGR and MAP sensor that were probably fine, but I'm not going to return the parts since they've been installed. I'm cheap, but not that cheap. I use it, I keep it!   I may or may not make money if I sell the truck at this point, but, that wasn't really the point. And if I billed my time, I'd be hosed for real. My thought on the tires is I "might" put 1,000 miles on before selling it. I just don't want to put absolute junk on it, that doesn't do anyone any good. If the Solus solidly isn't junk, I'll definitely consider them.
    • I leave mine as is. I'm always a trip away from riding on unpaved roads. Dealer can clean it when they prep it after I trade it in for another new truck.
    • I have these on two vehicles and love them. Pepper is one of them 😉
    • 4WD. Far as I know it came stock with P's and not LT's. Definitely planning to put P's on it, but stock is a 109 XL load rating so I should probably stick within that guideline.   No rebates on anything I can see at the moment. Discount Tire is offering $50 off, but Pep Boys is very competitive on price, and also carries all the off-brand stuff. Les Schwab always wants an arm/leg, but they do good work.   It still has the original spare. Goodyear Wrangler RT/S, thing looks like a tractor tire LOL!! How times have changed.
    • 2020 Sierra 2500 HD (base model) gas engine 4wd.    All 4 windows roll down on their own. Happens somewhat randomly after stop and engine off - when engine turned off, when walking away from vehicle before or after locks activated. Pulled the window fuse F14 Instrument Panel Fuse Block Right; the driver's side still activates from driver's side door panel; passenger and back seat windows activate from local switches on their doors but not from driver's side group of switches. Power mirrors don't activate with fuse removed either (same fuse for both circuits). Problem not solved.    How can they even activate with fuse removed but they are all still opening and can control from each door?  When they open on their own, I can shut them from the switch in each door, but they don't stay closed.    Seems to be activated somehow with key fob; something bumping the key fob in my pocket or just handling - removed key fob and took it far enough away and now the windows stay closed. Replaced key fob batty just in case, no change.    Sounds like some kind of wiring short or maybe electronics. Dealer will first replace electronic control module without checking anything else and I anticipate problem will still exist since their troubleshooting skills are limited to "do whatever the computer says".  In any case, keyfob seems to be activating the circuitry.    Surely I'm not the only one with this issue, but I can't find anything related on the site. What do yall think?   JohnRoy
