Increase Transmission performance
I have a 2004 silverado 5.3L. I have a k&n air filter with smooth air intake. Electric Fans, Hypertech programmer. I will be selling my programmer soon to get my truck dyno tuned at nelson performance.
I am wanting to know what i can do to my transmission to make it shift faster and stronger. Or will the guys at nelson performance also tune the transmission?
What all do shift kits include?
I have an 05 sierra 5.3, and I just got the Corsa exhaust today. I have a superchips programmer. Now, this truck has WAY too much power and the 1-2 shift is just not happening. I would be interested to know anything you learn. I'm concerned about blowing the thing up!
:D
marko
TransGo shift kit is the ONLY and RIGHT way to make a tranny perform the way it should. It is the true way to increase line pressure in the tranny. Its not an easy install but is the best single mod you can do to the 4L60E. After the kit is installed torque managment has to be removed. That can be done with a custom tuned PCM. There are many companys across the net that can do this via email for you. That tune will far surpass anything a handheld programmer could ever do.
Great link on the HD2 and install.
http://www.gmhightechperformance.com/tech/0407htp_projls1/
