Noisy Leaf Springs
My leaf springs are noisy, and have been since the day I bought the truck. Every time I hit a bump, the rear end makes a loud clakkity sound. The only thing I can think it would be are the leaf springs. I've inspected them (and everything else) closely and there doesn't seem to be anything missing, like rubber dampers or anything, and nothing appears broken.
My truck is a '99 K1500 ext. cab. P/U short box OBS, but my dad has the same issue with his 2003 4WD 2500HD ext. cab. P/U short box.
Has anyone else had this problem and found a fix?
Rear Leaf Spring Slap or Clunk Noise (Replace Spring Insert and Insulator) #03-03-09-002A - (Apr 29, 2004)
1999-2004 Chevrolet Silverado 1500/2500 Series Pickups
2000-2004 Chevrolet Suburban 2500 Series
2002-2004 Chevrolet Avalanche 2500 Series
2003-2004 Chevrolet Express 2500/3500 Vans with 8500 GVWR (RPO C5F), 8600 GVWR (RPO C6P) or 9600 GVWR (RPO C6Y)
1999-2004 GMC Sierra 1500/2500 Series Pickups
2000-2004 GMC Yukon XL 2500 Series
2003-2004 GMC Savana 2500/3500 Vans with 8500 GVWR (RPO C5F), 8600 GVWR (RPO C6P) or 9600 GVWR (RPO C6Y)
This bulletin is being revised to add models and update the labor time. Please discard Corporate Bulletin Number 03-03-09-002 (Section 03 -- Suspension).
Condition
Some customers may comment on a rear leaf spring slap or clunk noise. This noise is most apparent when the vehicle is operated over irregular road surfaces.
Correction
Verify that the rear leaf spring inserts (1) and insulators (2) are present on the leading and trailing ends of the overload spring (second stage leaf). The insert may have broken apart from wear and fallen out. If the insert and insulator are not present, install new ones.
Important
On some models, the vehicle may have to be raised to allow the springs to separate enough so the insert can be installed.
Parts Information
Part Number
Description
15604067
Insert, Spring Leaf
15053476
Insulator, Rear Spring Leaf
Parts are currently available from GMSPO.
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
E5168*
Insulator and/or Insert, Rear Leaf Spring - One or All - Replace
0.3 hr
* This is a new labor operation number. The next update of the Labor Time Guide will contain this new number.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
The simplist and cheapest fix is simply go to your local hardware store and buy yourself some 2.5" to 1.5" rubber pipe fitings. Its the soft black rubber stuff for ABS drain pipe. Im not exactly sure whats its made of but they are simply a reducer fitting. They work perfect for the noisy leaf springs. They will slide right over your preload spring thats slapping around. I put some on my 2000 1500 :fume: 30k ago and they are still in perfect shape.
:confused: DUDE! thats my repair! Did you figure it out on your own or from my posts here? It works great and costs like 1.89 per. great minds think alike!
Thanks for the advice. I'll have to plead ignorant, though. Which is the preload spring?
Bron- These slip over the "helper"or "overload" spring. It is the lowest spring in the spring stack. The one that looks like its kinda seperated. take the reducer and put one each(front and rear-4 total) on the helper spring leafs about 3 inches in from the end. I got my reducers at a sears hardware and put'em on in the lot, zippo-presto no more clanking. If you jam them all the way up against the other springs it will noticibly stiffen the rear, i found that has not a good ride and backed off to approx the OEM location(should see the OEM holes in the spring)
No way!!!.............thats hilarious.................I figured that out on my own. I figured that if GM is just going to sell us a piece of rubber to put on the leafs than I might as well do it myself. Its not a cosmetic issue so plumming parts work just fine...... :fume:
I think I have a similar problem, but I think it's coming from my front left torsion bar. I tried adjusting it the other day, and ever since then if I drive over a speed bump I'll hear a little clink or two. Same problem and just a coincidence it happened when I adjusted the t-bar?
Thanks.
Thanks.
Will, I had an annoying clink or rattle or something from the front as well. turned out to be that the front brake pads were loose in the retainers(crappy aftermarket stuff) took forever to figure out. put in OEM pads and RETAINERS, she's quiet now. Reach into the caliper from behind with your finger, if you can sorta jiggle the pad around this might be your problem as well.
I just went to the local Ace Hardware and the flex couplers and/or reducers they have for ABS/cast pipe are pretty thick and come with hose clamps. They are about $4 each, or more than twice as much as the item suggested. I tried to flatten the 2" coupler and imagine sliding it onto the overload spring, but that didn't help. Maybe I'm looking at the wrong thing. Is there any way you can be more specific about the part you are sugggesting?
Ya, you're diffinately looking at the wrong thing. These reducers are no bigger around then a beer can(a refference we can all relate to!) I'll try to find a pic on the web(don't hold your breath)
Thanks Firsttruck.
I have been lurking on this one as I have this exact problem too.
Question, could you (or someone) Take a pic of where on the springs you are talking about to install the 'reducer'? Of cousre and the pic of the reducer as well....
Regards
Thanks Firsttruck.
Regards
:flag:Called Sears Hardware, guys says it's a p/n 83-44855
    • A complete delete is the most thorough mechanical solution, but it is also major engine work. On a quiet truck that is still under extended warranty, opening the engine purely as prevention is difficult to justify. A plug-in disabler stops commanded cylinder deactivation, but it does not remove or repair the collapsible lifters, so it should not be treated as failure insurance. I would keep the oil full, document the maintenance, and have any persistent tick, misfire, or loss of power diagnosed promptly. If the engine eventually has to come apart, that is the logical time to compare an OEM-style repair with a complete delete. The right choice depends on the truck’s symptoms, warranty status, expected ownership period, and whether the engine already needs to be opened. We explain that decision in more detail here—full disclosure, this is our own guide: https://www.bluev8.com/blogs/news/do-you-actually-need-an-afm-disabler   One exception: some 2021 L82/L84 trucks have RPO YK9, meaning cylinder deactivation was already disabled in the factory ECM; on those trucks a plug-in disabler is redundant, although the AFM/DFM hardware remains inside the engine.
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
