Spread the GM-Trucks.com word with this handout
Zane
Ever see another GM Truck at the mall, at work, or in a parking lot and think, "I wish I had something to place on their window to let them know about the site!" ??
Here's a simple black/white word document for you to print out and keep with you. For every page you print you get four hand-outs.
Here's what one looks like...
Just click and download this word document, clip the four apart and keep them in your glove box. When you see an potential member somewhere, slip this under their drivers side windshield wiper! For a nice personal touch, write "Given out by: Your username" on the back.
Here's for spreading the GM-TC bug!!
Hey_nice_truck.doc
Hey_nice_truck.doc
Hey_nice_truck.doc
Hey_nice_truck.doc
