Parking Brake
the blur
The parking brake in my 03 Denali goes to the floor, and doesn't really do much. I recently did rear pads too, but never even looked at the parking shoes.
We hardly ever use the parking brake, so I can't imagine the shoes are worn.
is there an adjustment? or do I tighten the cable like the old fashion cars?
The shoes wear out due to a weak clip that holds them in place. The shoe ends up laying against the drum and wearing because of that. No, you don't adjust the cable. Apply the brake three times, it's self-adjusting. Of course, if the shoe is worn out, that won't help.
A soft pedal that goes down what seems like more than normal is how these parking brakes are designed; however, if it does not hold the truck, there's a problem.
    President Roberto
    President Roberto
  • Who's Online   2 Members, 0 Anonymous, 193 Guests (See full list)
