Acetone as Fuel Additive
TonyMazz
Hey GM-Tech I know there is a TSB out there on warning people about Acetone and other additives in the fuel. Could you post it for me ?
There are some folks I know that insist that it's ok and GM made an official stance on it as well as some others and I just can't seem to get my hands on it...
Thanks
T
It's amazing what some people think up, isn't it? Here's the latest from GM on the topic.
Info - Fuel and Oil Additives - Facts and Myths/Maximizing Fuel Economy #05-00-89-072 - (Oct 24, 2005)
2006 and Prior All GM Cars and Trucks
2003-2006 HUMMER H2
2006 HUMMER H3
2005-2006 Saab 9-7X
Please direct this bulletin to the Service Manager, the Service Consultants, and the Sales Staff. A copy of this bulletin is encouraged to be given to your customer as it is written with the consumer in mind. You may also post this bulletin in your customer lounge or waiting area.
A Statement About Fuel Economy
As gasoline prices have increased, the consumer has shifted priorities to become increasingly concerned with fuel consumption. GM is presently proud to offer 20 cars in the U.S. with EPA highway estimates of at least 30 mpg. The information below contains reasonable and prudent advice for your dealership and the consumer to get the most from every gallon of gas.
The information below is presented in two easy to understand sections:
• What Not To Do: Engine and Fuel Additives, Alternate Fuels, and "Miracle" Products
• What to Do: Maximizing Fuel Economy/Minimizing Costs
WHAT NOT TO DO: Engine and Fuel Additives, Alternate Fuels, and "Miracle" Products
Various unproven products to improve vehicle fuel economy have been reported ranging from magnets that align molecules to chemical combustion improvers.
Most products claiming to provide benefits are based on unsubstantiated claims. Those that do present "scientific" results generally either have too little supporting data to be conclusive, have not conducted experiments in a controlled fashion, or cannot be substantiated by anyone else but the product's manufacturer.
The U.S. Federal Trade Commission summarizes results for products tested by the federal government at www.ftc.gov/bcp/conline/pubs/autos/gasave.htm. A review of the list shows that the majority did not work, and for those that showed some effect, the benefit was too small to be cost effective.
Harmful Ideas That May Damage Your Vehicle and Increase Emissions
One more recent poor idea to improve fuel economy that should not be attempted is to blend either kerosene or diesel fuel into gasoline. Why? Both kerosene and diesel fuel are distillate fuels meant for use in compression ignition engines, not spark ignition engines. They have very low octane and since they are heavier (higher density) than gasoline, they will cause heavy engine deposits and degradation of engine oil.
Notice: Never put Kerosene or Diesel Fuel in your Gasoline Engine vehicle. This may result in inconsistent performance and permanent damage to your vehicle that is not covered by your New Vehicle Warranty.
Chemicals that are normally used as solvents also should not be used. These include acetone, ketones, and methanol. These solvents can be incompatible with your vehicles rubber or sealing components, and may dissolve the vehicle’s paint finish. In the case of methanol, corrosion of metal parts in the fuel system also may occur.
Notice: Never use acetone, ketones, or methanol additives in your vehicle. Some of these solvents may damage or corrode your fuel system. They are also very damaging to the painted surfaces of the vehicle if spilled.
WHAT TO DO: Maximizing Fuel Economy/Minimizing Costs
The best fuel economy possible is the direct result of proper maintenance and good driving habits. Listed below are GM's recommendations to achieve the best mileage possible. The first group are things to consider for your vehicle, while the second are tips relating to your driving habits.
Vehicle Considerations:
• Tire Pressure - One of the major contributors to poor fuel economy are under inflated tires. Tires low on pressure create drag that the vehicle’s powertrain must overcome, wasting dollars in fuel. Always keep your tires inflated to the proper pressure as shown on the vehicle placard. This not only serves to increase gas mileage but cuts down on tire wear, further decreasing your costs per mile.
• Air Filter - A vehicle that has a dirty air filter can’t efficiently draw air into the engine. This restriction forces the engine to expend energy to "breathe" wasting fuel in the process. Change recommendations are found in your vehicle Owner’s Manual.
• Proper Viscosity "Starburst" Rated Oil - Always use the proper viscosity oil in your engine. Oil that has a higher than required viscosity will create more drag on the internal components of the engine, causing more work for it, especially when cold. Each Owner’s Manual contains information on the proper type of oil for your vehicle. Look for the "starburst" symbol on the front of the bottle, and the SM rating on the API circle on the back label. If you are in doubt, stop by your dealer for an oil change, and any other services required. Most current GM vehicles are equipped with oil life monitors to further assist on the "when" to change your oil. (Aveo/Wave/Optra/Epica currently do not have oil life monitors).
Notice: GM Vehicles DO NOT require additional engine oil additives. Some additives may cause harmful effects to the internal seals and additionally void the terms of your vehicles New Car Warranty.
• Top Tier Fuels - Some fuel manufacturers provide gasoline advertised asTOP TIER DETERGENT GASOLINE (Chevron, Conoco, Phillips 66, Shell, Entec Stations, MFA , 76, Somerset Oil, QuikTrip, and Kwik Trip in the U.S. and Chevron in Canada. These fuels are preferable when and where available. They help to keep your fuel injectors and intake valves free of deposits. Clean engines provide optimal fuel economy, performance and reduced emissions. When Top Tier fuels are not available, consider a bottle of GM Fuel System treatment PLUS, P/N# 88861011 (in Canada, #88861012), at oil change time which will remove intake system and injector deposits. GM does not recommend any other fuel system cleaner.
Important: DO NOT confuse Top Tier Fuels with Higher Octane (Plus/Premium Grade Fuel) commonly sold at most all gas stations. Plus and Premium fuels are required in some high performance GM vehicles. However, they do not necessarily represent higher detergency present in TOP TIER Detergent Gasoline.
Important: For additional information regarding Top Tier fuels and availability, please refer to Corporate Bulletin Number 04-06-04-047E for U.S. or 05-06-04-022 for Canada.
Notice: E85 FUELS: Only vehicles designated for use with E85 should use E85 blended fuel. E85 compatibility is designated for vehicles that are certified to run on up to 85% ethanol and 15% gasoline. All other gasoline engines are designed to run on fuel that contains no more than 10% ethanol. Use of fuel containing greater than 10% ethanol in non-E85 designated vehicles can cause driveability issues, service engine soon indicators as well as increased fuel system corrosion. See Corporate Bulletin Number 05-06-04-035 for additional information.
• Use the Recommended Grade (Octane) Fuel Purchasing higher than required octane fuel is a waste of money. Using higher octane fuels in a vehicle that only required regular unleaded fuel will neither increase performance nor improve gas mileage. In all cases refer to your owners manual and ONLY use the octane rated fuel recommended for your vehicle.
Important: In high performance GM vehicles that DO require Premium (91 octane or higher) fuel, you MUST use fuels of at least this octane. Use of lower octane fuel may result in reduced performance, knocking, and/or permanent engine damage not covered under the terms of the New Vehicle Warranty.
• Check Engine/Service Engine Soon Light - Is the Check Engine/SES light on? When this light is on, the vehicles On-Board diagnostics computer has noticed that something is wrong. GM vehicles have many sensors that the computer uses to both control and sense actual fuel usage. When the computer lights the Check Engine/SES light it has lost some ability to run efficiently. This may result in increased fuel consumption, increased emissions, and/or driveability concerns.
• Spark Plugs - Even though current GM vehicles have 160,000 km (100,000 mi) service intervals for spark plugs if your vehicle is at that point in it's life, have the spark plugs changed to assure proper running and continued efficient, trouble free operation.
Changes In Driving Habits:
• Slow Down, Drive Smoothly - Avoid quick/full throttle acceleration from a standstill in town and high cruising speeds on the interstates. While the optimum MPG for highway cruising speed varies from vehicle to vehicle, faster is almost always worse. If your vehicle is equipped with a Driver Information Center that displays Instant Fuel Economy, select that read out and vary your cruising speed while on the highway. The display will change continuously with uphill and downhill sections but you should quickly be able to identify on level ground the speed range that your vehicle does the best in.
• Empty Your Trunk - Avoid leaving unnecessary items in your trunk. It takes power to move increased weight and that means more gasoline consumption and reduced performance. While the change may be slight, multiplied by thousands of miles, it all adds up.
• Avoid Extended Idling - There is no need to idle your engine till it reaches operating temperature. Idling wastes fuel.
• Combine Trips - Your vehicle uses much more fuel when the engine is cold. This is especially true in the winter months when the engine will take the longest to warm up. Combine errands or trips so that the vehicle only needs to warm up once to encompass many different stops.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
    Gilkey96
    Gilkey96
  • Who's Online   5 Members, 0 Anonymous, 828 Guests (See full list)
    • Replace the fuel pump with an OEM AC-Delco.
    • Hello, first time posting here. I have an 03 Chevy 1500HD with the 6 liter gas engine. The truck ran fine until the fuel pump died on me and had to get it towed. Replaced the fuel pump with a precision pump from O’rileys and changed the fuel filter while I was there. The truck will run and drive now but it wants to idle around 500 rpm when in drive and it tries to stall if you touch the gas. It drives fine though, just doesn’t want to idle. Put a fuel pressure gauge on the rail and only have 50 psi. I guess these trucks should have 55-62 psi to run right. I thought the regulator might be the issue because when I would unplug the vacuum hose it jumped to 56 psi. Replaced the regulator and no change. The only thing I can think of is that I was sold a faulty fuel pump. Any help would be appreciated because I’d rather not have to take the bed off again if I don’t have too. Thank you!
    • I've been wrenching on GM trucks for 17 years. And I need to get something off my chest because it's been weighing on me for a long time. After all that time, all those motors, all those people standing in my bay, I've figured out there are really only two kinds of owners. The ones who already know about this. And the ones who are about to find out the hard way. A guy came into my shop a few weeks back in a 2018 Silverado 5.3. Sharp guy, maybe 35. Knew his truck cold. He'd been on the forums, read the threads, done his homework. He only rolled in so I could double-check a little module he'd already plugged in himself. Wanted a second set of eyes on it. Ten minutes, in and out, drove off happy. Two days later, a completely different story walked through the same door. Older fella this time, in a 2016 Sierra. Gorgeous truck, clearly babied, not a scratch on it. Wedding ring. Looked like a guy who took care of his stuff. He was in because his engine had started knocking on the way to work. And by the time I got the valve cover off, I already knew it was too late. Lifter collapsed. Cylinder 5. Camshaft chewed up. The whole top end shot. Same kind of truck. Same motor. Same roads, probably the same dealer. The only thing separating those two men was information. I've been at this since 2008, and I've worked on everything GM puts out. Silverados. Sierras. Tahoes. Yukons. Suburbans. Escalades. The 5.3 and the 6.2. Doesn't matter which badge is on the tailgate. They all carry the same problem. So here's the information one of those guys had and the other one didn't. It's called Active Fuel Management. AFM. GM started building it into their V6s and V8s back in 2007 to squeeze out a little better mileage on the highway. Maybe a mile or two a gallon. All to hit government fuel economy numbers. The way it works, the motor quietly shuts down half its cylinders when you're just cruising along. And the little lifters that pull that off have a tiny pin inside them that's constantly clicking in and out. Lock, unlock, lock, unlock. Hundreds of times a drive. Thousands of times a week. Eventually one of those pins wears through. The lifter drops. And it starts grinding the camshaft down like a chisel on butter. And what nobody tells you is that the shudder you feel around 40 or 50 mph? That's the system cycling. Every single time. Here's what really gets me. The pre-2007 trucks, the ones without AFM, they're bulletproof. I've got customers still daily driving them with 260,000 miles on the odometer. Not a problem in the world. GM took a perfectly good motor that would have lasted a lifetime and bolted this system onto it. And it is wrecking engines that should have run forever. The guys who hang around the forums already know all of this. So do the techs. They handled this years ago. They didn't sit around waiting for the dealership to mail them a warning letter, because that letter is never coming. It's the guys who figured somebody would've told them who end up on my lift. And I want to be clear, because this part matters. Maintenance has nothing to do with it. I've torn down motors with barely 30,000 miles on the clock. I pulled apart a Tahoe last summer with 24,000 on it. Practically a brand new truck. Owner had it less than a year. Spotless oil. Best synthetic money can buy, changed early every time. Made no difference. I've seen guys with full dealer records, every interval stamped. Made no difference. The oil changes were never the problem. The pin was. And no amount of babying that truck stops that pin from cycling every single time you drive. That's the part that eats at me. These are good motors. Take the AFM out of the equation and a 5.3 or a 6.2 will run 300,000 miles and never blink. So a few years ago I started telling every single owner who comes through my doors the exact same thing the smart guys already knew. Get yourself a FullForce disabler. It plugs right into the port under your dash. Couple of seconds and you're done. It just tells the computer to leave every cylinder running, full time. No more cycling. No more beating those lifters back and forth every time you turn the key. It doesn't reprogram anything. Doesn't touch your tune. And unplug it before a dealer visit and there's absolutely zero trace it was ever installed. I've had customers come back at 40,000, 60,000, 80,000 miles after I put one in. Zero issues. The trucks run smoother. And the lifters aren't getting beaten to death every single drive. I won't sit here and tell you it's magic. A lifter that's already damaged is a lifter that's already damaged, and this won't un-ring that bell. But it takes away the one thing causing all that wear in the first place. That's the whole game. You don't need a five-thousand-dollar delete. You don't need an expensive tune. You don't need to tear anything apart. You just need to stop the cycling. I'm not writing this for any company. I'm writing it because I'm tired of watching the guys who didn't know pay four and five figures for it. I'm tired of being the guy who has to break the news. I'm tired of knowing that the guys who did know fixed the whole thing for the price of a tank of gas, and the only difference was that somebody told them first. If you drive a Silverado, Sierra, Tahoe, Yukon, Suburban, or Escalade from 2007 or newer with a V6 or V8, you've got AFM. You've got those lifters, and they're cycling every single time you drive. So be the guy who already knew. Not the one I'm scraping metal out of next month. EDIT: A bunch of folks asked, so here it is. The one I put my faith in is FullForce. This is where to find it: https://www.tryfullforce.com/products/fullforce™-afm-dfm-disabler They back it with a 60-day guarantee too. I've handed out more than I can count and not one's ever come back to me. Not one. See less
    • Thanks for following along. I'm not author material, my tenses are all over the place and an editor would have a heck of a time cleaning up after me. Reading and writing is still a fun pastime though.   My new scanner came in yesterday, wow, where the heck has this thing been?! It connects right up to the Blazer, there's all kinds of bidirectional tests like EGR activation and percentage, toggle the fuel pump relay, EVAP purge valve, IAC control, AC relay, reset the transmission's adaptive learning, toggle shift solenoids and TCC lockup, and I can reset fuel trims with the click of a button...all things I could have used over the last 60 days!   It's also telling me there is a stored code in the ABS module for front left wheel sensor open and something about the brake switch. The ABS dash light works. It illuminates normally during the self-test at key on/ start and that's it. I cleared the codes and will see if they set when I take it out later. That, and I'm going to get (hopefully) real data on timing and cam ******. The PID's are there.   I connected the tool to my truck...holy smokes. Newer vehicles make early OBDII vehicles look like 8-bit, pixelated, early Nintendo stuff. This? This is like wearing 3D virtual reality goggles playing one of those elaborate, cinematic video games with seasons and plots in comparison. There are SO MANY modules and SO MANY tests and SO MUCH data. There's a scanner sequence for filling the coolant...   End of the day, it's a tool with way more power than I need, but the versatility to do old and new is there (and I need an adapter to connect it to my OBDI Camaro). It will allow me to do the first pass of diagnosis when out-of-warranty vehicles need help, and it will enable more DIY maintenance like brake system bleeding, ABS bleed, etc. I probably over-bought here, but, mission is accomplished.   Enjoy your Sunday...I need to shut this machine down and go get ready for the week ahead.
    • Not that I've read, after all the issues they've had in the past I'm pretty sure they learned their lesson.
