removing rear pads 2000 GMC 2500
trying to change the rear pads and rotors on my 2000 GMC 2500 with the 4 wheel disk. I can't get the torx bolts to break loose, is there a trick to doing this? I got the 2 18m bolts loose but can't get the pads out.
Tim
Tim
With just one of the two caliper bolts removed (actually it'll probably only work with the lower removed due to brake line length), you should be able to easily rotate the caliper about the other bolt and pop the pads out.
Otherwise, the trick is a longer breaker bar! Something I've always thought of trying but never has is to align the wrench horizontally and use a jack to push up on it. Probably not a good idea though =).
If you are going to go ahead and remove the calipers entirely, it would be a good idea to change the parking brake shoes as well. Once the calipers are removed, the rotors will slide right off, if they haven't been removed before there will be small metal clips holding them to the wheel studs, these are only there for faster assembly times at the factory and are not necessary. Just cut/pull them off, slide the rotor off, remove the clip holding on the shoes with a screw driver, work the shoes around the hub from one end to the other (At first it will seem impossible, but keep fooling with it), adjust the shoes (just like any other drum brake system, except the adjuster is built onto the pusherthingamabob), slam it all back together, and you're done.
yup, penetrating spray and a bigger bar, make sure you keep one hand on the torx bit, so you don't round it off, and one on the end of the bar and push.
I just took off the calipers and caliper brackets on my 1500. Ended up splitting an 18mm socket into three pieces, good thing I had a spare.
i stripped the torx bolt so now i can't loosen it but the good news is i figured out that i don't have to take those out. I got the two 18m out and then i can just slide the caliper back on that bracket and take the pads out of the back. The inventor of the torx bolts should be shot. Why don't they just use regular bolts? Also i was woundering my truck is a 3/4 ton with the hydroboost brakes and 4 wheel disk, do i have ABS? Because i don't see a abs system under the hood.
Tim
While i'm under there i should change my diff and transfercase fluids. I don't have my owners manual and i did a search on this site. From what i've read i need to run synthetic 75w-90 in the rear and 80w-90 in the front but i could not find anything on the t-case fluid(its manual shift btw). Anyone have the owners manual handy?
Tim
I would just get the T-Case fluid from your dealer.... I know the AutoTrac ones need the special "Smurf Oil", but the manuals don't, I beleive, but I'm not sure if you can still use it in the manual ones (smurf oil).
If I were you, when you take the 18mm bolts off for the caliper mounting braket, try to get the torx bolts out of the calipers then.... and when you go to the dealer, get the replacement ones.... its much easier when changing the pads to just unbolt the torx bolt, swing the caliper up out of the way and change the pads, then swing it back down.
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 634 Guests (See full list)
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
    • I'm putting in an A-pillar pod/gauges, and I'm asking if anybody can identify a (preferably) fuse for a switched power and illumination circuit on the driver's side interior fuse panel. Offhand, everything I checked with a test light was constant-hot, and I'd much rather uses a piggyback fuse. I can certainly find a wire, but I'd rather not half-tap.   Thanks in advance for any help.
