which headers to go with?
hey peeps whats up well im having trouble deciding which headers to put on my truck i was thinking about putting some hooker super comp. full length headers on my 2005 truck but i was also wondering will it void my facotry warranty> WOULD FULL LENGTH HEADERS ADD MORE EXHAUST LOUDNESS TO MY TRUCK.. BUT yea if yall got any ideas for headers and if it would make my exhaust more louod let me know asap2850hkr.jpg
